Problem with assignment syntax in VHDL
kender
Stanford, SF Bay Peninsula, California, Earth, Sol
hdlparsers:800
Colleague,
I’m learning VHDL by modifying cookbook examples. I’m using Xilinx WebPack and I have a problem within the following code:
signal wdt_clk_cnt: unsigned(23 downto 0);
wdt_clk_cnt <= wdt_clk_cnt + 1; -- this works
wdt_clk_cnt <= 0; -- ERROR here
Here’s the error message:
 ERROR:HDLParsers:800 - "E:/Relievant/gen2/PLD_firmware/watch_dog_timer.vhd" Line 58. Type of wdt_clk_cnt is incompatible with type of 0.
Why am I getting this error? Why can’t I assign a constant (a zero) to a variable? What would be the best solution?
Thanks,
- Nick
vhdl unsigned assignment
try
wdt_clk_cnt <= (others => '0');
unsigned as well as std_logic_vector and std_ulogic_vector behave in a manner that you can add some integer to them but you can't assign an integer, by writing (others => '0') you say that all bits of your signal are to be assigned as '0'
    kender
for loop syntax in vhdl
firefoxPL said:
try
Thank you! Your solution worked. Is there a place on the web where somebody with reasonable EECS background (mostly C/C++, microcontrollers and sensors) could look for this type of information?
vhdl reference manual
I started with quite similar programming background and one of the things that I learned is not to think like a c++ programmer, you need to learn basics of digital circuits, after you understand how digital circuits work you will be able to write much better VHDL codes, apart from that keep learning from some vhdl books and you should be all right :)
vhdl assignment problem
I basically agree with FireFoxPl. One thing is to know the HDL syntax, types and operators defined in the standard packages, that's almost easy to my opinion, the other is to understand the requirements of (mostly) synchronous logic and parallel processing.
It's very helpful, if you have designed digital hardware logic before. Than you are not at risk e. g. to write a VHDL for loop, wondering why the output isn't toggling. This is likely to happen when you approach HDL from the software side.
Learning from cookbook examples isn't bad, generally. It's also good, to have a detailed VHDL reference at hand. I finally stopped at the Synopsys VHDL Reference Manual. Xilinx has copied part of it in their manuals.
Some VHDL constructs are even missing in the Synopsys manual, e. g. using variables in generate statements. The IEEE VHDL standard, present at EDAboard, is the only complete reference, although not a convenient literature.
