do u know how many test inputs will come for 2 * 2 multiplier? 16 combinations. Then for 8 bit multiplier... Very large number...It will take u many days to write all the cases without missing..
The best way is to do the random test bench... use $random(f) function
deepu,
thatz the reason i am asking for some way to write a code which will test all cases.
Will $random work in VHDL?? I am working on VHDL of Modelsim.
I know that in Verilog you can run a for loop to generate all the cases but in the case of VHDL i am not sure if we can do...
