Looking for info about Booth Multiplier
Sadegh.j
Advanced Member level 3
Could someone please give me a link to read about booth multiplier
Thanks
Re: Booth Multiplier
HI
Hope this helps for u. Please click on helped if u find as helped one
Thanks and Regards
Deepak
    Sadegh.j
Hi
Thanks, do you anything on the implementation, you know different circuits to implement the multiplication. and the final adder?
Thanks
Booth Multiplier
I am currently working on that part.Multiplier is da part of the circuit. I am trying to implement wallace tree . The final adder in that part would be CLA. That will be more efficient. What is ur project?
Regards
Deepak
mine is a course project, nothing serious. An 8*8 bit booth multiplier
Booth Multiplier
u can easily do the multiplier from that doc.
hey,
i am also working on the Modified Booth Multiplier with the bit-pair concept...
are u too using the same?
guyz do u have any idea how can we write a test bench to test the 8*8 multiplier with all the possible cases without writing them manually...
Booth Multiplier
To test the 8x8 multiplier, your test bench could use a 16-bit counter to step through all possible combinations of the two 8-bit inputs, and then display a pulse or error message whenever the result differs from the HDL's '*' multiply operator.
