About Constraints and Attributes (Xilinx)
wasp
Junior Member level 3
Russian Federation
How it is possible to receive the set delay of a signal on output FPGA?
The project on Spartan. I use ISE4.1 + Synplify (VHDL).
Or how it is possible to use attribute "X" in VHDL? Whether is such constraints which forbid to delete logic at stage Map?
hi...as far as i understood ur question...tool always try to optimise the design...and reduce the timing...if u want to increase the delay..then u have to go to floorplan and place the logic away from the pin....
and ur second question i didn't follow it...attribute "X"..
and ur third question...to keep the logic without being deleted try the attribute "KEEP"....
hope it helps..
