How to use the cores that are available in Xilinx ? (VHDL)
triump.ar
Junior Member level 2
how to use the cores that is available in xilinx...i m not getting..plz give me an idea....i m new to vhdl...plz help
instantiate
basicaly You add "New source" which in this case will be an "IP (CORE Generator....)" than You choose which IPCore you want to use and setup it, after you press "Generate" (or "Finish" or something like that) and chosen IP appears in the source list, You chose it and click "View HDL Instantation Template" in Processes window, it generates VHDL code from which component goes between "architecture" and "begin", and port mapping goes after "begin"
