sharada.144
Newbie level 5
Hi all. This is the vhdl code I have written for parallel to serial converter and its testbench. The testbench output is not changing accordingly. Please can any one tell me what is wrong with the testbench I have written. Please its urgent.
Thanks and regards,
Sharada
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity p2s is
port( clk: in std_logic;
rst: in std_logic;
par: in std_logic_vector(7 downto 0);
ser: out std_logic);
end p2s;
architecture behavioral of p2s is
signal q: std_logic_vector(7 downto 0);
begin
--clk<= not clk after 100 ns;
process(clk, rst)
begin
if(rst='1') then q<="00000000";
elsif (clk'event and clk='1') then
q<= '1' & q(7 downto 1);
-- q<= '1' & q(7 downto 1);
end if;
end process;
ser<=q(0);
end behavioral;
Testbench:
library ieee;
entity p2stb is
end p2stb;
architecture behavioral of p2stb is
component p2s
rst: in std_logic;
end component;
signal clk: std_logic := '0';
signal rst: std_logic := '0';
signal par: std_logic_vector(7 downto 0) := "00000000";
signal ser: std_logic;
begin
clk<= not clk after 50 ns;
U1: p2s port map(clk=> clk, rst=> rst , par => par, ser=> ser);
process(clk)
begin
rst <= '1';
--wait for 50 ns;
rst <= '0' after 50ns;
par <= "10101010";
end process;
end behavioral;
Thanks and regards,
Sharada
library ieee;
entity p2s is
rst: in std_logic;
end p2s;
begin
process(clk, rst)
begin
end if;
end process;
ser<=q(0);
end behavioral;
Testbench:
library ieee;
entity p2stb is
end p2stb;
component p2s
rst: in std_logic;
end component;
begin
process(clk)
begin
rst <= '1';
--wait for 50 ns;
par <= "10101010";
end process;
end behavioral;
