Problem with communicating 2 PIC16F876 using I2C bus
Frank1313
Newbie level 2
I2CREAD HELP
I WRITE A PROGRAM TO DO A COMUNICATION ,USING I2C BUS AND 2 PIC16F876..
THE SLAVE USE ASSEMBLER,AND I THINK IS O.K.
THE MASTER USE PICBASICPRO,AND CAN'T RECEIVE THE DATA.
I USE THIS CONFIGURATION:
DEFINE HSER_BAUD 19200
DEFINE I2C_SLOW 1
DEFINE ONINT_USED 1 ' BOOTLOADER
SCL VAR PORTC.3 ' Clock pin
SDA VAR PORTC.4 ' Data pin
FromSlave VAR BYTE 'dati arrivati dallo Slave
Letture VAR BYTE ' Dati letti da ADC (funzione non implementata)
Test VAR PORTA.0
SSPCON= %00101000 ' Setta il dispositivo in Master Mode
SSPADD= %00001001 ' 100KHz con Fosc 4MHz
PORTA= 0
TRISA= %11111110
PORTB=0
TRISB=0
PORTC=0
TRISC=%10111111
FromSlave=0
CICLO:
I2CRead SDA,SCL,2,[FromSlave],ERRORE
GoTo CICLO
someone can tell how work I2CREAD??
THANKS
If something in C helps, look at:
HH
NeuralC
I dont know what code your basic compiler produces, but to read I2C, you send a start, then a write to the address, then a restart, and then a read.
Re: I2CREAD HELP
If you need to know how the I2C bus works here is a good document (the i2c standard):
best regards
Re: I2CREAD HELP
DEFINE I2C_SLOW 1
Test VAR PORTA.0
PORTA= 0
TRISA= %11111110
PORTB=0
TRISB=0
PORTC=0
TRISC=%10111111
FromSlave=0
CICLO:
GoTo CICLO
THANKS
Frank I am planing to do similar but not have tried yet . I have seen melabs site and there are codes for doing this tak go run and find em there and do tellus if that worked ?
Ts
