RFID Tag Antenna design . Matching Chip impedance using CST
GVVIN
impinji
I need some help on How to match antenna to high impedance of tag chip using CST studio .
For example I need to desin an antenna for impinji Monza chip for Tag design. How to go about.
rfid design using cst
Hi GVVIN
Use conjugate of chip impedance example Monza2 single end connection antenna imp should be 52+j158 @915 MHz and in cst use discrete port 50 ohm feed you can learnning structure concept from impinji website in actualy real part of ant must be lower than chip resistance.
good luck
    GVVIN
    pis1101
rfid tag using cst
Hi crazyeng,
Could you please help in in locating the docyument you specified in Impinj website . i am unable to find that. I do have an impinj user login.
Regards
GV
    pis1101
antenna design for rfid using cst
hi .. could you tell me please how the rule to design patch antenna for rfid reader?
