+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 4
    Points: 2,219, Level: 10
    Join Date
    Nov 2006
    Posts
    226
    Points
    2,219
    Level
    10
    miller compensation
    In Gray it is said single stage opamps,such as the telescopic cascode or folded cascode,have only one gain stage;therefore Miller compensation is not possible.
    Why? Can I attach a miller cap between negative input and single ended output?
  2. #2
    Member level 1
    Points: 1,355, Level: 8
    Join Date
    Apr 2007
    Posts
    40
    Points
    1,355
    Level
    8
    miller compensation in amplifiers
    Because at high frequencies because of the forward transmission through the Cc(basically a zero @ high frequencies) there would be no gain left in a single stage.
    However in a two stage, you would design it in such a way that stage1 still has gain.
    Also in general, stability is not an issue in single stage opamp(consider a differential to single ended opamp).
    It has two poles : One @ high impedance output node which is the dominant pole and another @ low impedance current mirror node which is the non dominant pole.So you would have a PM of about 90 degrees in single stage, so why bother to compensate it further and slow down the transient response?
    1 members found this post helpful.
    •   Alt11th April 2008, 00:27
      advertising
  3. #3
    Advanced Member level 1
    Points: 3,875, Level: 14
    jecyhale's Avatar
    Join Date
    Feb 2008
    China
    Posts
    403
    Points
    3,875
    Level
    14
    op amp miller pole
    Quote Originally Posted by leohart
    I think we use miller compensation for improve the stablity of the circuit. but the miller compensation will reduce the gain of amplifier, so if the single stage opams should be easy to be stable, so miller compensation is not useful here.
  4. #4
    Full Member level 6
    Points: 4,115, Level: 15
    Join Date
    Jan 2006
    Posts
    399
    Points
    4,115
    Level
    15
    single stage op amp stability
    right, there is such big stability issue in case of single stage opamp...
    •   Alt11th April 2008, 17:11
      advertising
  5. #5
    Full Member level 4
    Join Date
    Nov 2006
    Posts
    226
    Points
    2,219
    Level
    10
    dominant pole compensation
    I know there is no stability problem in single stage, and of course Gray knew...so why did he bother to say "cant use miller compensation in single stage opamp" isnt it weird?
    ps:
    [quote="A_U_J"]Because at high frequencies because of the forward transmission through the Cc(basically a zero @ high frequencies) there would be no gain left in a single stage.
    quote]
    Isnt what does miller compensation do is just eliminate gain at high frequency to make sure gain<0dB before the phase reach 180degree?So what does your comment mean for gain at that time?
    anyway thx for your comments, they are good, ;)
    •   Alt15th April 2008, 15:20
      advertising
  6. #6
    Points: 11,124, Level: 25
    Achievements:
    7 years registered
    safwatonline's Avatar
    Join Date
    Nov 2005
    EGYPT
    Posts
    1,347
    Points
    11,124
    Level
    25
    miller compensation in op-amp
    i don't get what u mean.
    adding miller capacitance is to do pole splitting between two nearly dominant pole.
    so in ur description u r adding the miller between the input (ideally: no pole there) and the output (usually the high impedance node(dominant pole)) what will u gain from that (except maybe making the dominant pole less dominant and generating a new dominant pole !!)
  7. #7
    Full Member level 4
    Join Date
    Nov 2006
    Posts
    226
    Points
    2,219
    Level
    10
    what is miller compensation on amp
    hi,A_U_J,can u explain it for me?
    hi,safwatonline,do you mean in two stages, we do miller compensation,then we get a dominant pole in the input of the second stage.but in a single stage,the dominant pole is at the output which diffs from the two stages,so miller compensation cannot work properly.
  8. #8
    Newbie level 2
    Points: 1,462, Level: 8
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    Points
    1,462
    Level
    8
    miller compensation in op-amp.
    Miller compensation is done is introduce a zero at the pole position and cancel the effect of the pole. but in a telescopic cascode , between which two nodes can you introduce a zero to cancel it out? introducing Cc between negative terminal and output seems a bad idea.
    •   Alt17th April 2008, 04:41
      advertising
  9. #9
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    EGYPT
    Posts
    1,347
    Points
    11,124
    Level
    25
    miller compensation,what is dominant pole?
    Yep.
  10. #10
    Full Member level 2
    Points: 2,070, Level: 10
    Join Date
    Sep 2006
    Santa Maria
    Posts
    146
    Points
    2,070
    Level
    10
    You can put the miller capacitor between input and output of a single stage amplifier. It's just not useful at all, since the dominant pole is usually at the output already, and there's no second pole being pushde higher in frequency.
    Don't forget that the stage that drives your amplifier input has finite ouput impedance.
    The miller capacitance that you will generate *at the input* will severely limit the BW of the system... The output pole was pushed a bit higher in frequency, while the input pole was brought much lower. Ideally the input pole was *not* the BW limit before the miller capacitor was inserted (otherwise your single-stage has too much BW w.r.t. the signal BW), so the poles are now closer together. There's also the transmission zero, but as long as the miller capacitor is much smaller thant the load capacitor it'll not make the bad result much worse.
  11. #11
    Points: 10,068, Level: 24
    leo_o2's Avatar
    Join Date
    Sep 2004
    China
    Posts
    1,324
    Points
    10,068
    Level
    24
    op amp miller capacitor output impedance
    Yes, in single stage amp, output node will be dominant pole. But miller effect will push output node pole to high frequency that will worse the stability.
