How to find Input referred Noise in a circuit using cadence
steadymind
Full Member level 4
USA
I need to find the input referred noise of a folded cascode amplifier in cadence. please help me. any material would also do .
thanks
Re: How to find Input referred Noise in a circuit using cade
Use noise analysis in spectre. In the noise analysis setup window, choose your input voltage source as your input noise source. Run the analysis and then go to
Results>direct plot>noise, you will be able to display the input referred noise in v^2/Hz or V/sqrt(Hz)
    steadymind
