Problem with updating Xilinx to ver. 5.2
ASIC
Full Member level 3
xilinx update
I used to run Xilinx 3.3i. After installing it, it installs Synopsys FPGA Express, and everything works fine. Now I try to install Xilinx 5.2 and after all is installed, there is no synthesis or place and route tool that can handle VHDL. What am I doing wrong?
ASIC
hi
Don`t you have VHDL XST synthesis tool in project properties window?
besides you can install leonardo spectrum 2001. and use in in ISE.
Re: Xilinx Update
Try Start/Programs/Xilinx ISE 5/Project Navigator.
There you will be able to create new project and synthesyse using XST.
Synopsys is not developing FPGA Express anymore, so it is nomore supported. Try Xilinx's own free synthesys tool (XST) or better tools like Synplify/ leonardo spectrum which you have to buy saperately.
OK I see. I don't see the XST synthesis tool in the project window. I guess it should be there. I'll try to install again on a fresh installation of Windows.
ASIC
Re: Xilinx Update
Hi ASIC,
Just in case you didn't know. X!linx ISE Alliance does not include XST, Foundation does and is slightly more expensive.
Check this out:
and
If you have Foundation you'll find XST available as soon as you add VHDL (o verilog) files to your project in project navigator.
Regards,
-Maestor
try to get Edit>Preferences>partner tools
browse the synopsys executable. Then go to device_name>properties and select the synthesis tool you want. I think should be ok
