I need a XILINX Spartan3 XC3S400-FT256 ORCAD CAPTURE Symbol
h_humble2001
Newbie level 2
xilinx orcad symbol
I need a XILINX Spartan3 XC3S400-FT256 ORCAD CAPTURE Symbol. Can someone please help me in this regard.
Thanks
xilinx orcad
That may help.
ep20k
ft256
it is easily to do it yourself.
xc3s400
Check here: **broken link removed**. If you can't find the footprint among the files, you can also post the request.
It's tedious to do it yourself. How long do you think it will take to make a symbol for a chip with 256 pins?
xilinx orcad lib
With pad array generator in OrCAD library manager about ten minutes or less...
orcad capture xilinx
What versions of OrCAD have this pad array generator? Which menu is it at?
xilinx fpga orcad symbol
- Layout Plus 10.5.0, but maybe in sooner versions too.
- From Layout's shell select Tool/Library Manager - Library Manager runs.
- In Library Manager's menu select library and then click Create new footprint button. Dialog appears. In lower section of dialog called Options check Use Pad Array Generator. Then click OK and Pad Array Generator runs. Screenshot of imaginary 5x5 BGA array included as example...
spartan 3 orcad symbol
Thanks! However, I had Capture in mind when I posted the response that doing components by yourself is tedious. I don't know of a tool that automates the creation of Capture components or import of them from other formats.
orcad symbol xilinx
You are right - my misunderstanding. I use @ltera's FPGA and in QII is possible to export .PIN file, than can be used for some automation of creation Capture symbol, but i don't know Xilinx. So, yes, it is tedious...
