How to select FPGA chip for baseband modem?
fryFox
Junior Member level 1
Hi, I want to do a project about baseband modem based on FPGA, but I don't know how to select an appropriate chip for it , can any body help?
and the modultation rate is 50Mbps.
Thank u advance!
Cmon folks, this stuff is not rocket science so forgive me if I sound a bit sarcastic:
First step: Determine the design specs or requirements
Second step: Generate a block diagram of system based on first step
Third step: Choose device based on second step
Fourth step: If you find during the design process that the device you choose is too small then move up to a larger part.
If any of the above is too hard to understand you probably should not be doing hardware design.
    fryFox
Maybe some Virtex... You'll surely know when you describe your design in HDL and finish implementation on specified device - it`ll either fit and meet timing, or not.
Thanks for your suggestion, I am new to the field and i just received the task. but i don't know how to start.
