What is the difference between convolution and correlation?
sundarmeenakshi
Full Member level 3
Convolution
What is the differance between convolution and correlation
Re: Convolution
correlation is used to compare the similarity of two signals, the result is a signal that shows this similarity and reaches its maximum at the time when the two signals match best. correlation can be used to measure the delay of a certain system.
convolution is used to compute the output of a certain linear system when a certain input signal is applied to it. this is done by applying convolution between the input signal and the impulse response of the system
    sundarmeenakshi
    V
Re: Convolution
From mathematical point of view convolution of two function is:
x(t)*y(t)=∫x(Θ)y(t-Θ)dΘ
and correlation is
E[x(t)y(t)]=∫x(Θ)y(t+Θ)dΘ
Re: Convolution
Convolution is the operation / transformation that governs the i/p - o/p relationship in a LTI system.
Correlation is a statistical measure of how similar two waveforms or random processes are.
In the case of a matched filter, correlation and convolution becomes the same.
Convolution
convolution is specifically used for the multiplication of continous and discrete time signal in time domain and valid for LTI system but correlation is matching and comparision of signal and there are two types auto and cross correlation and its example in missile imaging
Added after 22 seconds:
convolution is specifically used for the multiplication of continous and discrete time signal in time domain and valid for LTI system but correlation is matching and comparision of signal and there are two types auto and cross correlation and its example in missile imaging and using correlators and matched filters for taht
Re: Convolution
Convolution of two signals can be interpreted graphically as folows:
supose you take convolution between x(t) and y(t). Then in t domain just reverse the signal y(t) i.e. plot the signal y(-t). Now translate the signal y(-t) from -∞ to Γ. The overlap area is the convolution between x(t) and y(t). at the point Γ.
On the otherhand the correlation is the same thing, only thing is that, you dont have to invert the signal y(t) in t domain. Translate y(t) itself from -∞ to Γ. The overlap area gives the correlation between these two signals.
Convolution
Completly agree with asoom
Convolution
Correlation + Shifting = Convolution
This is the difference between the both.
