Solution to "Plot command failed" on Fedora 7
siroos.toofan
Newbie level 1
Plot command failed
I installed the cadence IC5.1.41 on fedora 7. in the analog environment window i choose the type of analysis and outputs, but after simulation it give this warning and this causes that I can not save the states. It put . And .. instate of states names.
- Warning -
<COM.cadence.awd.graph.GraphManager@180a8b7>
Plot command failed: cannot open data set tran-tran in results directory /home/siroos/simulation/ss/spectre/schematic/psf
Re: Plot command failed
This is Linux to cadence compability problem. You can try one of the follow...
1. Try to update the icfb (what usr pack are you using?)
2. Change Fedora 7 to Fedora 4, it works well.
