What kind of information need be drawed in the schematic?
shineqi
Member level 1
When the analog circuit engineer pass the schematic to the layout guys, what information must be provided?
Thanks
Re: What kind of information need be drawed in the schematic
MOS matching, wire width , resister matching , capacitor matching...
apart from these things area (cell height or width constraints), shielding, diff pair are impoortant.
resistor width and current drawn should also be emphasized in the sheet.
max current over process, temperature, voltage corners
matching
key routing, parasitics, especially in high-frequency application.
balancing
Substrate noise consideration; High Voltage guard line & ESD rule
