help on ASM code for LM35DZ and PIC16F877A
freedoms
Newbie level 5
asm coding for pic(16f877a) microcontroller adc
HI Everyone,
I'm doing a digital thermometer by using LM35DZ temperature sensor and PIC 16F877A microcontroller. Can anyone teach me how to use the ADC inside 16F877A to convert the output of the LM35DZ or can anyone share the code how to interface between the ADC and LM35DZ. Pls advise!
Thanks for your help....
pic16f877a asembler codes examples
Check the PIC datasheet and the microchip website for the application notes.
lm35dz
You should be able to find a lot of examples on the web.
adc en assembler con 16f877a
1. Enable the necesary pin as input, and configure as analog.
2. configure the ADC: read all about the configuration registers of ADC in the datasheet (select the channel, select the sample time,...)
3. read the ADC (enable ADC), and wait the data converted, this can be done by a loop or an interruption.
In google there is a lot of examples search by:
ADC example pic16f877
