collinear omni-directional high gain antenna design?
winglj
Full Member level 4
Hi, everyone, I have a question about the omni-directional high gain antenna design.
Basically, the topology I want to use is a series of half-wavelength wires collinear aligned. The connections between them are spring coils. But how can I determine the dimension of the coil in order to make the phase of the half-wavelength section are in-phase?
Any references will be appreciated. Thanks.
The inductor should be calculated to change the phase between elements with 90 degrees.
If you are using λ/2 coaxial segments you don’t have to use any inductors between elements.
    winglj
I have seen this type of antenna referred to as a "Franklin" . That may be of some help.
I have not been particularly impressed with the results of this type of series feed. Hopefully, you will get it working.
    winglj
