How to use the PIC to PC interface (16F877a) using the MAX232?
anwar147
Newbie level 3
KL, Malaysia
hi guys.. im new in microcontroller and still learning. i just established my programmer and program using CCS C compiler. i just also learned and it was my first time to give output to the assigned port.
My question is that when and how to use the PIC to PC interface using the MAX232 chip that connected to serial port.
Re: PIC16F877a
best answer would be just google
you will find out thousands of sample circuit
here is the little description or guide
use hardware UART which is built in the pic
for this RC7 & RC6 should be connected to the Max232
possibley there will be a example on ccs c compiler
PIC16F877a
Interface chip or circuit can shift RS232 signal to TTL and vice versa.
Re: PIC16F877a
most {all} modern controllers for rs232 on serial pc ports {made after 2000} will auto switch to 5v
so the max 232 isnt needed really.. just buffer diodes 1n4148.... on rx tx and rts cts ...
Re: PIC16F877a
ok. nice guys, but if im going to connect the MAX232 hardware, what is actually going to happen, do i need any or different sofware, and what its purpose then :|
PIC16F877a
you do not need software in MAX232, read the post of funnynypd what MAX232 do
PIC16F877a
Google is full f schematics showing how to connect them.
PIC16F877a
one more thing, actually i am controlling my 7.5 degrees per step stepper motor, the minimum delay each step that i did is 0.03 sec, below than that the motor wont move, for a stepper motor, how high the RPM can go, and also im using ULN2003 chip for the motor driver
PIC16F877a
The is a minimum response time from driver circuit and motor coil. CHeck the data sheet of those devices.
