stepper motor controller code using C language
yazid
Junior Member level 1
johor,MALAYSIA
hi..i have a coding to control speed for stepper motor using assemble languange..but now..i want a coding by C language to control the speed of the stepper motor by vary the frequency...
Use the parallel port.
Write a program to send the bytes to parallel port.
Now if you want to vary the frequency.. You can set the output bytes accordingly.
Set a for loop and may be a user kbhit break or escape from the loop.
Get the frequency input from user. You can set the corresponding delay using the bios functions.
Thanks.
Regards.
