What is a Pseudo-random Noise (PN) sequence?
pn sequence in cdma
A Pseudo-random Noise (PN) sequence is a sequence of binary numbers, e.g. ±1, which appears to be random; but is in fact perfectly deterministic. The sequence appears to be random in the sense that the binary values and groups or runs of the same binary value occur in the sequence in the same proportion they would if the sequence were being generated based on a fair "coin tossing" experiment. In the experiment, each head could result in one binary value and a tail the other value.
what is pn sequence
You seem to have an incredible thirst for knowledge, as I have spotted 17 threads from you, all on them single phrase postings with subject and message body identical, and all of them posted within an hour. YOU ARE FLOODING the forum. You can use wikipedia or google to find answers to your questions, instead of posting 7 new threads in a timespan of 5 minutes.
sumant.thapliyal said:
"how gunn diode work", 05 Sep 2007 12:37
"how make laout of n-mos in tennar", 05 Sep 2007 12:37
"what are negative resistance devices", 05 Sep 2007 12:39
"what is tcpip prtocole", 05 Sep 2007 12:39
"what is cdma", 05 Sep 2007 12:40
"what is pinging", 05 Sep 2007 12:43
"assembly code for text to speech conversion", 05 Sep 2007 12:54
"what is qpsk?", 05 Sep 2007 12:55
"WHAT IS PN-SEQUENCE?", 05 Sep 2007 12:56
"what is resonance in rf circuits?", 05 Sep 2007 12:57
"what is horn anteena and its basic principle of operation?", 05 Sep 2007 12:57
"WHAT IS DIFFERENCE BETWEEN ASIC AND ASIP?", 05 Sep 2007 12:58
"WHAT IS DIFFERENCE BETWEEN CPLD AND FPGA?", 05 Sep 2007 12:59
"vhdl code for MUX(1-16)", 05 Sep 2007 13:20
"vhdl code for MULTIPLIER(32-BIT)", 05 Sep 2007 13:21
"WHAT IS RESONENT CAVITy", 05 Sep 2007 13:24
pn sequence cdma
It looks more to someone that is doing a
homework.
cdma pn sequence
PRN sequence is used in GPS rx for time to first fixed when at least 4 satellites are visible...
pn-sequence
PN stands for pseno random codes in CDMA.PN is assigened at each sector of BTS wn a subsriber come in to that sector that PN is updated.in a BTS each sector has one PN.Each PN has a differnce of 168.for example let α has PN 4.then θ will have PN of 168+4=172 then √=172+168=340
:D
what is pn in cdma
PN codes are generated using LFSR(linear feedback shift registers).
pn sequence generator in digital communication
PN as already defined by fellow members is a unique identifier for a sector or cell of a CDMA BTS. There are 512 PN codes for assignement depending on the assignment strategy. PN can sometimes be refered to as short code.
The MS decodes the PN to identify the serving BTS Or the cells in the active, candidate and neighboring lists. It is thus important to have a good PN offset plan to avoid PN confusion by the MS.
In big networks, PN re-use patterns are deployed. If interested, let me know so i upload the related mathematics.
pn offset plans
they are sequences used in CDMA to spread the transmitting data. there are some algorithms to generate these codes
types of pn sequence
it is the code for the spread spectrum communication .
it can be used to synchronize the local pn code to the received pn code.
cdma pn planning wikipedia
PN sequences are usd for 2 types of spread spectrum techniques:
1) Direct Signal Spread Spectrum (DS-SS)
2) Frequency Hop spread Spectrum (FH-SS)
If u use PSK for modulating the PN seuence, it results in DS-SS
If u use FSK for modulating the PN sequence, it reults in FH-SS
