didibreakit
Newbie level 2
Hello, I’ve never built anything in regards to electronics and really don't know the first thing about it, but I want something and am asking for some help.
I want to be able to push a button (the button needs to be at least 4 inches from circuit board) and then have 4 color LED lights to blink one right after the other in a circular motion very fast and after a couple of seconds of doing that I want it to RANDOMLY pick a light and for that light to stay shining. (Kind of like a roulette table?) I want it to stay lit up until I push the button again and then I want the process to repeat itself and I always want the light it stops on to be random.
And if that wasn't enough I need to be able to select which lights are used. I'm not going to need all 4 lights all the time so I'll need 4 little switches that I can turn on/off each corresponding to a different LED. So one time I can have all four LEDs in play and another time I have two LED's switched off so only two LED's will flash back and forth until one is randomly selected.
It's a lot I know, but can it be done? And would it be really difficult to do? Is their any such KIT that I can buy to do it or is there a site that explains how to build things like that you can point me to? I'm also not looking to spend a lot of money, this needs to be able to be done cheap. Would making something like this cost a lot? I'd appreciate any and all help with this, Thanks!
