proof that 2+2 = 5 weird
Full proof without mind cuts :]
(just copied and added few more lines)
Start with: -20 = -20
Which is the same as: 16-36 = 25-45
Which can also be expressed as: (2+2)^2 - 9 x (2+2) = 5^2 - 9 x 5
Add 81/4 to both sides: (2+2)^2 - 9(2+2) + 81/4 = 5^2 - 9 x 5 + 81/4
Rearrange the terms: [(2+2)- 9/2)]^2 = (5-9/2)^2
this is because... [(2+2)- 9/2)]^2 = [(2+2) - 9/2][(2+2) - 9/2]= (2+2)^2 + 81/4 - 9 - 9 -9 -9= (2+2)^2 - 9(2+2) + 81/4
and... (5-9/2)^2= (5- 9/2)(5-9/2) = 5^2+81/4 - 45/2 - 45/2= 5^2+81/4 - 45 = 5^2+81/4 - 9x5
Square root the equation: [(2+2) - 9/2)]^2 = (5-9/2)^2 to get (2+2) - 9/2 = 5 - 9/2
Add +9/2 to both sides to get:
2+2= 5
SQRT(a²) = |a| (absolute value of a)
so √[(2+2)-(9/2)]² = √[5-(9/2)]²
becomes |(2+2)-(9/2)| = |5-(9/2)|
and not (2+2) - 9/2 = 5 - 9/2
Sorry forgot about that :)
hmm but than... if you add 9/2 to both sides does it still work?
No. According to order of operation, you must do the math inside the absolute value bracket first.
here is one that works better:
-20=-20 (it is fact)
16-36=25-45 (16-36=-20,25-45=-20)
4^2-36 = 5^2-45 (4^2=16,5^2=25)
4^2-36 = 5^2-45
4^2-2.4.9/2 = 5^2-2.5.9/2 (2.4.9/2=36,2.5.9/2=45)
4^2-2.4.9/2 +(9/2)^2 = 5^2-2.5.9/2 +(9/2)^2 (adding both the sides (9/2)^2
[4-(9/2)]^2 = [5-(9/2)]^2 (let 4=a,9/2=b)
4-(9/2) = 5-(9/2)
4 = 5
2+2 = 5
---------- Post added at 11:35 ---------- Previous post was at 11:34 ----------
here's another one
Let x be a non-zero number, and set y=x. Thus:
x = y
x^2 = xy
x^2-y^2 = xy-y^2
(x+y)(x-y) = y(x-y)
x+y = y
2y = y
2 = 1
1 = 0
Now since 2+2 = 2+2+0 and we apply the lemma proof so that 0 = 1, 2+2+0 = 2+2+1 =5
THEREFORE
2+2 = 5
First off, the square root of a number leaves the possibility of it being positive or negative so
(5-9/2)^2 = (4-9/2)^2
+- (-.5) = +- (.5)
Giving you
-.5=-.5
Or
.5=.5
Or
|.5|=|.5|
And
If x = y
Then x - y = 0
And you can't divide by zero so
(x+y)(x-y) = y(x-y)
Is not
x+y = y
Which can also be expressed as: (2+2) 2 (9 X (2+2) = 52) 9 X 5
Add 81/4 to both sides: (2+2) 2 (9 X (2+2) + 81/4 = 52) 9 X 5 + 81/4
Rearrange the terms: ({2+2}) 9/2) 2 = (5-9/2) 2
Ergo: 2+2 - 9/2 = 5
Hence: 2 + 2 = 5
It's so weird title and I am not getting how do you solve this type of problems. I think you should express 3rd line in well matter and why we go through this equation?
Here's a formula known as Euler's equation. It's for real and it is paradoxical.
E is the well known important constant which is the base of natural logarithms.
I is the square root of minus 1.
https://betterexplained.com/articles/intuitive-understanding-of-eulers-formula/
At last moment, taking the square root is the part when above proof gets messy.
On doing so, you have only considered the positive sign.
Actually x^2=4 is x=+2 or -2.
You didn't take the negative part.
Also remember that both the results are not necessary to be true.
Only one may be true.
Here you chose the false one i.e. positive part.
Every mathematics that leads to absurd result arise from some misconception and mistakes.
Here's a webpage calling Euler's formula 'a beautiful equation':
Quote:
"Euler's equation expresses a universal truth, valid in any language or culture. It contains five of the most important numbers in maths: 0, 1, e, i, and π, along with the fundamental concepts of addition, multiplication, and exponentiation. These vital numbers and concepts also crop up in branches of science, engineering, and technology. All these ideas in just a few squiggles - if that's not beautiful, what is?"
can you prove it out and state how they are tied to each other
There is nothing much to "prove" there. It's just a little fun identity when you write out i^i. As in basically just a little shuffling of terms. Anyways, the result being this:
i^i = exp(-pi/2)
which I found cute. :)
2 +2 = 5
John has 02 bags of sugar of 1.25 kg each.
Maria has 02 bags of sugar of 1.25 kg each.
02 bags + 02bags = 04bags = 05kg
therefore:
02 +02 = 05
The relativity of Einstein in physics shows that the perception of the world depends on the viewpoint of the observer.
In mathematics is also possible to give a different result depending on how conventional applies equation.
02 bags of sugar plus two bags of sugar is equal to five 5kg of sugar.
hugs,
Bogdan
Please dont violate the very basic operations. Division by zero is not defined.
