i2c protocol software implementation
Fan174
Good evening to all
There are so many document's available on the internet for I2C communication and I have spend hard time to understand I2C software protocol
I am not looking for any code. I want to understand how does it work so I made one flow chart that explain my understanding
I have attached PDF file and I am looking one guide who can help me with my flow chart.
  • i2c1.pdf
This is not a general I2C communication flow chart.
It as a dedicated DS1307 I2C communication.
Thus please refer to the DS1307 datasheet. There are three figures (4, 5 and 6). Please say which one you want to implement. Then compare them step by step with your flow chart.
There are mistakes. But you did a good job. Drawing the flow chart is the best way to really understand the interface.
I also like your naming:
"Generate" is a bit manipulating process
"Send" is an 8 bit shift process (I´m not sure you are aware of this, because of the right bottom part)
"Get" is a one bit read process
Confusing is the right bottom part. With "i<7"...
Here - I think - is a mistake. I can just guess that this should be the inner loop of the "send" process.
Also note:
* In the DS1307 datasheet figures there is only one "I2C Start" per figure, but your flow chart includes three "I2C Start" procedures.
* At "data write" procedures the SLAVE needs to set ACK.
* At "data read" procedures the MASTER needs to set ACK except the last one. --> you additionally need to implement "SET ACK"
To prevent you from the most often made I2C implementation mistake:
Mind: I2C never sets an output HIGH. A HIGH is generated by an external pullup resistor and the I/O set to HIGH_IMPEDANCE.
Valid output states: DRIVE_LOW or HIGH_IMPEDANCE.
Reactions: Fan174
    Fan174
@KlausST I am really sorry for not defining title clearly. I am not very good in english. I want to learn i2C bit banging
I want to implement figure 6.
Hi,There are mistakes. But you did a good job. Drawing the flow chart is the best way to really understand the interface.
Thanks for encourage me to make flow chart. There are the different opinion in every link I will look each problem step by step
so can you point my some mistake so I can improve flow chart
Your flowchart is wrong. It generates new start with register address, however start has to be send exclusively before the slave address.
I suggest to refer to the original Philips/NXP I2C specification. **broken link removed**
Reactions: Fan174
    Fan174
How I´d check it step by step:
  • i2c1_mod.pdf
Reactions: Fan174
    Fan174
I saw datasheet and I am making flow chart for figure 9
I have attached new flow chart
Does it match with figure 9 ?
I have modified flow chart according to figure 6
I don't understand if I get Ack How to read data n to Data n+x
Please see my Flow chart I2C 4
  • i2c2.pdf
  • i2c4.pdf
Get philips(nxp) AN10216.pdf. The proper protocol is given on page. 11.
Make a flowchart for the specified one.
@KlausST I need your help,
I do not understand how to implement below in flow chart
DATA TRANSFERRED (X+1 BYTES + ACKNOWLEDGE); NOTE: LAST DATA BYTE IS FOLLOWED BY A NOT ACKNOWLEDGE (A) SIGNAL)
My flow chart is incomplete, after ACK I have to read many bytes how to do that
Reading an 8 bit wide "data" byte is similar to
outputting an 8 bit "word address" or sending the 8bit "slave address + R/W".
it is a loop running 8 times per byte: like this.
* n= 8
Loop:
* SCL = 0
* wait (during this phase the master or slave OUTPUTS data)
* SCL = 1
* wait
* READ state of SDA = data bit "n-1 of a byte" (MSB first)
* n = n -1
if n>= 0 goto LOOP
(now you have 8 bits = 1 byte read)
then you have to do the 9´th bit communication for ACK
run this for as many bytes you want to read.
wait time: if you want about 400kHz bit rate, then one bit time is 2.5us. Since you have two waits per bit the wait time should be about 1.25us
refer to UM10204, Fig 38 for timing.
refer to UM10204, Fig 5 for SDA and SCL sates
Mind
* idle sate is: SCL = 1 and SDA = 1
* Before performing an "I2C_START" be sure that the bus is in idle sate. If it is not in idle state: perform an "I2C_STOP" before the "I2C_START"
* A single bit communication starts with SCL=1 and ends with SCL=1. This is also true for a ACK communication ans well as a 8 bit data communication.
* to end a communication always perform an I2C_STOP
Reactions: Fan174
    Fan174
Thanks Klaus, That's excellent explanation
I have modified my flaw chart to read many bytes @KlausST Please see attached flow diagram
I am not very good at Embedded c programming.
This is my attempt to store the byte using array pointer in c language
#include<stdio.h>
int main(void)
    int array[8]= {5, 4, 6, 8, 9, 7, 8, 8};
    int *pointer = &array[0];
	int i;
    for( i = 0; i < 8; i++ )
        printf("\n Array[%d] is %d ",i,*(pointer+i));
	for( i = 0; i < 8; i++)
        printf("\n %d at %u ",*(pointer+i),(pointer+i));
    return 0;
Output of code
Array[0] is 5
Array[1] is 4
Array[2] is 6
Array[3] is 8
Array[4] is 9
Array[5] is 7
Array[6] is 8
Array[7] is 8
5 at 6422280
4 at 6422284
6 at 6422288
8 at 6422292
9 at 6422296
7 at 6422300
8 at 6422304
8 at 6422308
  • I2c5.pdf
you forgot about ACK after each byte.
I now marked it red in my post#9
Please read the recommended documents.
I´can read a bit, but can't write at all....
Please take a look at new flow chart. I have added Ack after each byte. Let me know if I am making mistake somewhere
I understand I am making flow chart to understand basic first. Once I complete flow chart then I will try to convert it into program
  • i2c6.pdf
Correct, except for: You are reading 9 bytes instead of 8. And you miss to generate the NACK after last byte.
Thanks for pointing mistake
see the new flow chart Does it look's okay
  • SPI7.pdf
Looks good now
Then I would try next step. I have to write code for each box in flow chart
according to Datasheet AN10216-01 I2C
START and STOP Conditions
START: A HIGH to LOW transition on the SDA line while SCL is HIGH
STOP: A LOW to HIGH transition on the SDA line while SCL is HIGH
pseudo code : This code will not compile and run. It's just for understanding
SDA        PIN1
SCL        PIN2
define High  1
define Low   0
void Generate_I2C_Start ();    //Declare the function
void Generate_I2C_Stop ();    //Declare the function
void main (void)   //start from here
     while (1)  //infinite Loop
        Generate_I2C_Start ();  //generate i2c start conditions
according to this A HIGH to LOW transition on the SDA line while SCL is HIGH
What would be routine Generate_I2C_Start (); ?
Which processor are you working with?
Driving SCL or SDA to high level is done by tri-stating the port pin. Except for peripherals with open drain pin like 8051 this needs programming the direction register.
Code C - [expand]
8
// assumed state before start
SDA = Z;
SCL = Z;
// Generate start
SDA = 0;
delay;
SCL = 0;
delay;
Hi FvM,
I would prefer 8051
This is new version of pseudo code It's little bit different then the original flow chart
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
#define SDA P2_1        /* Set P2.1 = SDA */
#define SCL P2_2        /* Set P2.2 = SCL */
define High  1
define Low   0
void I2C_Initialize (void)     //Declare the function
void I2C_Delay (N)             //Declare the function
        I2C_Initialize ();     //  idle sate is: SCL = 1 and SDA = 1
// This function give N nuber of delay
void I2C_Delay(int N)
    unsigned int i;
    for( i= 0; i < N; i++);
// Initialize idle sate is: SCL = 1 and SDA = 1
     SCL = 1   // set SCL pin to High
     SDA = 1   // Set SDA pin to High
void Generate_I2C_Start (void)
    SDA = Low;  // Clear SDA Pin
    I2C_Delay(2);  //Required delay
    SCL = Low;   // Clear SCL Pin
please don´t get sloppy now. Stay focussed. Read our posts.
from post#2:
from post#9:
@KlausST , @FvM
I am still stuck to convert block into coding. Can you give some hint's how to go for further process
