fatwolfning
Can somebody tell me what the "negative impedance" is ? and what is its usage?
fatwolfning said:Can somebody tell me what the "negative impedance" is ? and what is its usage?
ALL electricity obeys Ohm's law!A negative resistance is one which does not obey Ohm's Law.
Op-amps do not compose of a negative resistance! They compose only of transistors, diodes, semiconductor resistors and semiconductor capacitors.I know from book that the op amps can compose of a negative impedance,but the book doesn't tell me its usage.
smyback said:A -purely- negative impedance IS a negative resisistance!
Z = V/I, if Z is purely negative you have negative resistance!
If a voltage source is applied to a negative resistance load, then current will flow from the load to the source, instead of the other way!
A positive resistance dissipates energy, a negative resistance sources energy!
Therefore it is impossible to realise a negative resistance using passive components, it must have it's own power source (ie. it needs to be an active device!).
