skwok
Newbie level 6
I have made s simple dipole with lumped port at center and variable air box size.
The impedance changes quite a bit versus air box size.
I think HFSS recommends at least 1/4 lambda from antenna element.
Zreal changes from 82 ohm to 95 ohm when size increases from 1/4 to 1 lambda at 1GHz.
The minimum Zreal at 82 ohm is when size is exactly 1/4 lambda.
Theoretical Zreal is 73 ohm.
Could somebody please explain to me why Zreal changes so much when size increases?
I cannot get down to 73 ohm, any suggestion?
Thanks.
Thanks.
