SMD SOT23-6 Component Marking Code BR79
dexter_04
Newbie level 5
Hi everybody,
I'm looking for a component marked BR79.
I've made a lot of research on google with the following tags :
for the package, I've tried with : TSOP6, SOT457, SM6, SMT6, Mini6, SOT23-6, SC-74, SC-59-6
and for marking : BR79, BR7, BR
I've also made the schematic, and I think this component is like a kind of transistor.
Pin 1 is connected to VCC (5V)
Pins 2 & 5 are connected to GND
Pin 3 is connected to the µc (I think is the command)
Pin 4 is also connected to the µc (maybe is a status ?)
Pin 6 is connected to a resistor.
I think when this component is driven, the resistor is put in the circuit (like the circuit is a switch).
If you have any information, I'll be very happy.
Thank you in advance,
Fabrice
upload a photo of the PCB, where we can see all the connections.
You said you have a schematic, then upload it. Hand drawn is O.K.
Tell us what the PCB is for.
Thank you for your answer.
The PCB is a milkmeter (from delaval).
The two components that I'm looking for are U10/U11.
Fabrice
What about digital pot / EPOT / EEPOT?
yes, it looks like a digital potentiometer as R56 is not populated (see second picture).
Are pin 3 & 4 of both ICs are connected to a microcontroller? They seem to be the programming lines.
What's the device name "CI_MM27"?
greets
Thanks for all your answers, I'll see about digital potentiometer.
Yes, pins 3&4 are connected the µc.
CI_MM27 is the name that I put because I didn't know these components (that why I'm looking for them). CI is for Integrated Circuit and MM27, the name of the PCB.
the pinout of MCP4023 (https://www.microchip.com/wwwproducts/en/MCP4023) can correspond to that (even if the marking is different).
Fabrice
Dear all,
With your help, I finally found my component, it's a MCP4013T-103E/CH.
Fabrice
