Dummyeng
Member level 4
How can Transmission line does not see Stub?
Hi
Here you can see my design (it is only schematic and the values do not correct)
AGAIN my values in schematic do not correct
my first question from this design
as you can see some times diode should be off at this time all of power should receive from port 1 to port 3
but when that diode is off Tl2 is like an Stub and change Antenna Impedance
how can i do something that port 1 only see port 3 and i have not any change impedance and power dissipation in port2?
Hi
