Incisive Intallation using Installscape
Puppet123
Full Member level 6
Want to install Incisive add on to Cadence DFII using Installscape on Centos 6.
Do I tell Installscape where DFII installation is already and then install Incisive ?
Does Incisive have to be installed before Cadence DFII or can it be installed after the Cadence installation ?
Any special considerations for Centos ? Will Incisive work on Centos ?
Thank you.
No, you can install anywhere you like. The installations are independent (-ish) of each other.
It will work, but it is not a supported platform, thus if you bump into issues, you might have to solve them a bit creatively. Centos is quite similar to Redhat which would be your starting point.
https://www.cadence.com/content/dam...uments/support/supported-platforms-matrix.pdf
