Phase shifter 90 degrees
neazoi
Advanced Member level 6
Greece
Page 6 and 7 of the attached document, the figure 6C is a variable phase shifter (90 degrees). Do the shunt capacitors need to be tuned at the same capacitance value both or it can be different?
  • 9301032.pdf
They need to be the same value to keep the impedances of the I and Q branches equal. Note that the shift changes with frequency so simple RC or LC delays are only suitable for a very narrow range of frequencies and ideally need tuning for exact 90 degrees at each frequency used.
I agree with: both C should have the same value.
But doesn't shift one path to positive phase, while the other shifts to negative phase.
...in a way that the phase difference between both paths is always 90°? In a wide range of frequency..
Actually the example attached (with Xc=XL=50ohm) shows that the phase response is not wide range.
And to keep the impedance constant you have to change not only the values of C but also of the value of L, which makes the circuit pretty hard to tune.
I was mistaken, I referred to figure 6A.
