shaiko
Taken from this link:
https://www.intel.com/content/www/u...n-software/vhdl/vhd-single-clock-syncram.html
The following code is an Intel VHDL template for inference of "Single Clock Synchronous RAM".
As far as I understand - it will have a "Read Before Write" behavior when the same address is accessed.
Question:
Can you think of a way to change the above to behave as "Write Before Read" ?
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY ram IS
GENERIC
ADDRESS_WIDTH : integer := 4;
DATA_WIDTH : integer := 8
PORT
clock : IN std_logic;
data : IN std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
write_address : IN std_logic_vector(ADDRESS_WIDTH - 1 DOWNTO 0);
read_address : IN std_logic_vector(ADDRESS_WIDTH - 1 DOWNTO 0);
we : IN std_logic;
q : OUT std_logic_vector(DATA_WIDTH - 1 DOWNTO 0)
END ram;
ARCHITECTURE rtl OF ram IS
TYPE RAM IS ARRAY(0 TO 2 ** ADDRESS_WIDTH - 1) OF std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
SIGNAL ram_block : RAM;
BEGIN
PROCESS (clock)
BEGIN
IF (clock'event AND clock = '1') THEN
IF (we = '1') THEN
ram_block(to_integer(unsigned(write_address))) <= data;
END IF;
q <= ram_block(to_integer(unsigned(read_address)));
END IF;
END PROCESS;
END rtl;
Question:
