northumber82
Member level 3
Hello, my problem it's a bit complicated.
I want to measure the magnitude (in dB) of the bode plot of a specific frequency after an AC analysis.
In my configuration:
1) I have a circuit (a simple low pass or an high pass filter)
2) I change with the command STEP the value of a resistor
3) For the resistor values where (X)Hz is higher than (Y)dB save the resistor value in the Error Log
It's possible to do with MEAS command combined with STEP param and automate LTspice?
