yuyee
Junior Member level 2
Pardon me for having many questions.
Please give some comments/suggestions to enlighten me.
1) In the RF circulator datasheet, I saw "forward power and reverse power", can anyone explain what is that about?
2) what are the things that need to know when using circulator?
3) Does a circulator require 50ohm matching for all ports? In what way we can achieve 50ohms? what will happen if I did not achieve 50ohms?
4) signal flowing from Port 1 will flow to Port 2, and signal from Port 2 will flow to Port 3. Does the signal from port 3 will flow to Port 1? By right based on board design, signal shouldn't flow from port 3 to port 1.
Best Regards,
yuyee
Best Regards,
yuyee
