Offline Flyback...single stage, 55W, fully dimmable, no electrolytic capacitors
T
treez
We are doing an offline 55W PFC’d Flyback SMPS LED driver. (fully dimmable)
It is a single stage converter, with a constant off time flyback, and uses no electrolytic capacitors.
The schematic and LTspice simulation are as attached. One of the issues which is of concern is that the inverting opamp U11 in the pdf schematic (MCP6001U) , may for a short instant get a voltage on its inverting input that is more negative than minus 300mV. The datasheet doesn’t hint towards problems, but do you believe that this could cause reliability issues?
MCP6001U datasheet:-
https://www.mouser.com/ds/2/268/21733h-26779.pdf
  • Flyback PFC 55W.pdf
  • PFC flyback 55W ConstantOffTime.txt
This is not informative.
Is it 301mV? This is within the abs. max. specification.
Or is it 3000mV? This is beyond specification.
Don't expect problems as long as you keep within specifications.
Reactions: treez
    T
