NJ176
Newbie level 5
Hello!
I am working on ADC and DAC interface for Spartan - 3A board and I have checked the output of the amplifier which works. But I am having issues with ADC and DAC. I am displaying the 8 MSBs of the ADC on the LEDs, but all the LEDs are always lit.
I had set the clock the frequency to 1.5MHz from 1MHz and finally 1KHz, yet there is no change in the output. The code is given below. Can someone help me figure out the problem?
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity ADC is port ( enable : in std_logic; --switch enable for start preamp and adc clk_div : in std_logic; start_AD_CONV : in std_logic; --switch enable for start adc SPI_MISO : in std_logic; AD_CONV : out std_logic; --SPI-bus for ADC ADC1 : inout std_logic_vector(13 downto 0); --VINA ADC2 : out std_logic_vector(13 downto 0); --VINB AMP_CS : out std_logic; --SPI-bus for preamp SPI_MOSI : out std_logic; SPI_SCK : out std_logic; DAC_CS : out std_logic; AMP_SHDN : out std_logic; --preamp DAC_CLR : out std_logic --dac ); end ADC; architecture Behavioral of ADC is type state_type is (amp_state, adc_state, dac_state); type amp_state_type is (IDLE, START, HI, LO); type adc_state_type is (IDLE_AD, START_AD,LO_AD,HI_AD,FINE_AD); type dac_state_type is (da_idle, da_send, da_sck1, da_loop, da_end); type state_type_clock is (clock_on, clock_off); signal state: state_type := amp_state; signal amp_state_reg: amp_state_type := IDLE; signal adc_state_reg: adc_state_type := IDLE_AD; signal dac_state_reg: dac_state_type := da_idle; signal state_clock : state_type_clock := clock_off; -- Clock state set to clock_off signal sck_reg: std_logic:='0'; signal da_data_reg: std_logic_vector (31 downto 0) := "00000000001100000000000000000000"; -- signal for the DAC signal da_bit_reg : natural range 0 to 32; signal ADC_COPY: std_logic_vector (13 downto 0) := (others => '0'); -- a copy of the ADC-value to use for the DAC signal clk_sample : STD_LOGIC := '0'; -- Clock Sample is initalized to zero signal counter1 : integer range 0 to 34; -- Counter up to 34 signal risingedge : std_logic := '1'; -- For clock of rising edge signal count1:integer:=1; signal tmp : std_logic := '0'; begin -- 1.5MHz clock process(clk_div, enable) begin if(enable='0') then count1<=1; tmp<='0'; elsif(clk_div'event and clk_div='1') then count1<=count1+1; if (count1= 25000) then -- 1KHz frequency --25 for 1MHz tmp <= NOT tmp; count1<= 1; end if; end if; end process; sclk_clock : process(clk_div) -- Process for state of clock begin if(rising_edge(clk_div)) then -- When rising edge, clock state is set to on case state_clock is when clock_on => -- When clock is on, set SPI_SCK = clk_sample SPI_SCK <= tmp; when clock_off => -- When clock is off, set SPI_SCK = 0 SPI_SCK <= '0'; end case; end if; end process; --START PROCESS PREAMP - ADC - DAC process(clk_div) variable count: integer range 0 to 16; -- 14 bits for 1 ADC channel+2 for zero variable counter : integer range 0 to 34; -- 34 SPI_SCK clockchanges for an entire ADC-loop variable gaincount: integer range 0 to 7; -- 8 bits preampsignal constant gain_temp: std_logic_vector (7 downto 0):= "00010001"; -- biggest range of preamp begin if clk_div'event and clk_div ='1' then case state is --START AMP CYCLE when amp_state => DAC_CS <= '1'; --non active SPI-bus for DAC case amp_state_reg is when IDLE => gaincount:=7; if enable = '1' then amp_state_reg <= START; else AMP_SHDN <= '1'; AMP_CS <= '1'; amp_state_reg <= IDLE; end if; when START => AMP_SHDN <= '0'; state_clock <= clock_off; SPI_MOSI <= '0'; counter := 0; AMP_CS <= '0'; amp_state_reg <= HI; when HI => state_clock <= clock_on; counter := counter+1; -- The counter was set to 0 SPI_MOSI <= gain_temp(gaincount); -- gaincount is set to be 7 amp_state_reg <= LO; when LO => if counter = 8 then -- When 8 bit transferred AMP_SHDN <= '1'; -- Shut the amp AMP_state_reg <= IDLE; -- Go to IDLE state SPI_MOSI <= '0'; -- Set all the outgoing data to zero AMP_CS <= '1'; -- Basically, do the tasks assigned by the state IDLE gaincount := 7; state_clock <= clock_off; state <= adc_state; -- When done communication, go to ADC else state_clock <= clock_off; -- If counter less than 8 gaincount := gaincount-1; -- Decrease the gain count (from 7 to 6 and so on) amp_state_reg <= HI; -- Go to HI to do the serial transfer end if; when others => -- Any other situation - Go to IDLE amp_state_reg <= IDLE; end case; --START ADC CYCLE when adc_state => DAC_CS <= '1'; case adc_state_reg is when IDLE_AD => counter := 0; state_clock <= clock_off; AD_CONV <= '0'; if enable = '0' then state <= amp_state; else if start_AD_CONV = '1' then AD_CONV <= '1'; adc_state_reg <= START_AD; else adc_state_reg <= IDLE_AD; end if; end if; when START_AD => state_clock <= clock_off; AD_CONV <= '0' after 5 ns; count := 16; adc_state_reg <=LO_AD; when LO_AD => state_clock <= clock_off; if count > 0 then -- Count is initialized to 16 count := count-1; end if; counter := counter+1; -- Counter was set to 0 adc_state_reg <= HI_AD; when HI_AD => state_clock <= clock_on; if counter <= 2 then adc_state_reg <= LO_AD; elsif counter > 2 and counter <= 16 then ADC1(count) <= SPI_MISO; adc_state_reg <= LO_AD; elsif counter > 16 and counter <= 18 then count:=14; adc_state_reg <= LO_AD; elsif counter > 18 and counter <=32 then ADC2(count) <= SPI_MISO; adc_state_reg <= LO_AD; elsif counter = 33 then adc_state_reg <= LO_AD; else adc_state_reg <= FINE_AD; end if; when FINE_AD => counter := 0; count := 16; state_clock <= clock_off; ADC_COPY <= ADC1; AD_CONV <= '0'; adc_state_reg <= IDLE_AD; state <= dac_state; when others => adc_state_reg <= IDLE_AD; end case; --START DAC CYCLE when dac_state => case dac_state_reg is when da_idle => AMP_CS <= '1'; AD_CONV <= '0'; DAC_CS <= '0'; DAC_CLR <= '0'; state_clock <= clock_off; da_bit_reg <= 32; da_data_reg <= "00000000"&"0011"&"0000"&ADC_COPY(13 downto 2)&"0000"; dac_state_reg <= da_send; when da_send => DAC_CLR<='1'; SPI_MOSI <= da_data_reg(da_bit_reg); -- da_bit_reg <= 32; dac_state_reg <= da_sck1; when da_sck1 => state_clock <= clock_on; da_bit_reg <= da_bit_reg-1; -- Reduce the da_bit_reg by 1 every time the state dac_state_reg <= da_loop; when da_loop => state_clock <= clock_off; if da_bit_reg > 0 then dac_state_reg <= da_send; else dac_state_reg <= da_end; end if; when da_end => dac_cs <= '1'; state_clock <= clock_off; dac_state_reg <= da_idle; state <= amp_state; when others => dac_state_reg <= da_idle; end case; when others => state <= amp_state; end case; end if; end process; --SPI_SCK <= sck_reg; end Behavioral;
