digital pot resolution
garimella
Full Member level 5
Why digital pots come with low resolution? Can they not implement R-2R ladder as in DAC to improve their resolution?
I don't know. Maybe because of cost, size, power requirement..
If you want a DAC, you are free to use a DAC.
The primary use of digital pots is for circuits that need a variable resistor or a true potentiometer which doesn't work with R-2R ladder. The resolution is respectively limited by the feasible number of analog switches.
