KD494
Member level 5
- Joined
- Jun 24, 2015
- Messages
- 83
- Helped
- 13
- Reputation
- 26
- Reaction score
- 13
- Trophy points
- 1,288
- Location
- Boston, MA
- Activity points
- 2,059
So I have an analog path of a few stages of op amps. I tested it over a wide range of frequencies (100kHz-20MHz) and got more or less the results I expected in terms of gain, bandwidth, noise, and quiescent current. However I noticed that once I reach 5MHz or so the current from my supplies is suddenly jumping by a factor of two or so. The output voltage pk-pk had not changed, the load is an ADC that can handle these frequencies and should still be high impedance and the chain is not visibly going unstable. What other reasons could there be for the increases power supply draw that is so dependent on frequency of excitation?
