question about the impedance matching of Gilbert mixer
healthy
Newbie level 5
We can do the impedance matching with S parameter. But it is well-known that the S parameter is correct only for linear part,on which the testing signal is small. At the LO port of mixer, the signal is large.How can I do the impedance matching?
Thank you for your help!
Are you measuring or simulating?
Hello, I am simulating. Thank you.
Are you using ADS? You can do it by LSSP and HB pallete...
Goodluck....
Thank you. But I use the cadence`s spectreRF, what can I use?
in also specreteRF u can get the large signal input impedance of the LO port of the mixer , and design ur matching circuit
in some cases the matching crcuits are not needed at all . if both the Osc. and Mixer are integrated , so the matching circuit is not needed
khouly
LO matching isn't critical...
