Help me design a CMOS integrator
jilkdr
Newbie level 6
I need help in designing a CMOS Integrator with the following specifications.
Gain = 1000;
Small-signal Bandwidth = 1Mhz;
O/P voltage swing = 2V(peak-to-peak);
I would be grateful if the schematic is given with all the specifications and biasing.
Thank you
integrator cmos
It is not hard if you do it use your head~
Do it yourself~
cmos integrator circuit schematic
The gain, BW and o/p swing u refer is for opamp or integrator??
You need to know the specifications such as the power supply voltage rail, power dissipation for determine the opamp structure. :D
The specifications are for the opamp.
