about sigma-delta modulator
jiangxb
Full Member level 3
hangzhou, china
hi all
i have design a sigma-delta modulator chip, and now i'm measuring it. i found a question: the filtered output signal of modulator has disconnected case, as blew. in general, there are often these disconnects after a time interval. this is a 2-2 modulator.
I'm not sure, but may be it is due to an idle tone .Just guessing .
Maybe it's a data buffering problem, such as an overflowing FIFO, causing blocks of data to be repeated or skipped.
    jiangxb
hi ieropsaltic and echo47
these are possible, but i will verify them.
this plot is a output when input is a dc. this disturb often occurs.
One easy way to check for a data buffering problem is to apply a low frequency triangle wave, and look for strange output discontinuities.
try putting some BSF stoping the one at the disconuity. if t fine then it is the problem of tones.
hi sriramachandra
what is BSF? can you explain in detail? i should how to do? thank you.
hi echo47
maybe this is a buffering problem indeed. i used a data acquisition card to acquire the data from modulator, when i set larger buffer allocated, the discontinuity disappear.
thank you very much!
