Results 1 to 8 of 8
21st May 2007, 19:12 #1
- Join Date
- Apr 2007
- Posts
- 22
- Helped
- 0 / 0
- Points
- 1,093
- Level
- 7
free running vco
Anyone give some explaination.
Thanks .
Advertisement
21st May 2007, 20:18 #2
- Join Date
- Oct 2003
- Location
- EGYPT
- Posts
- 2,368
- Helped
- 462 / 462
- Points
- 15,234
- Level
- 29
give the meaning of vco
this is the frequency , which will be out of the VCO without applying the control voltage ,
khouly
23rd May 2007, 07:00 #3
- Join Date
- Apr 2006
- Posts
- 35
- Helped
- 2 / 2
- Points
- 1,961
- Level
- 10
free running vco vs. locked vco
It's the frequency of the VCO outside of a PLL, yes I agree, it is the oscillation frequency when there is not a control voltage.
Advertisement
23rd May 2007, 14:59 #4
Re: What's VCO free-running meaning ?
VCO can have a control voltage and still be un-locked. Steering a VCO with a voltage from say a variable bench PSU does not make it locked. I would say free-running is anything outside the closed PLL loop. A loop can be opened and the control voltage can go either pin high or low, depending on the design.
Wording from a patent document
BACKGROUND OF THE INVENTION
Electronic devices such as RF (Radio Frequency) receivers, transmitters and various other devices include a VCO operating within a PLL (Phase Locked Loop) to maintain a desired oscillation frequency.
It is conventional practice to tune a VCO to a particular initial frequency before it leaves its factory. This is typically accomplished by using factory equipment to measure the frequency of the VCO while it is free-running (i.e., the PLL is opened),
27th May 2007, 22:05 #5
- Join Date
- Apr 2007
- Posts
- 22
- Helped
- 0 / 0
- Points
- 1,093
- Level
- 7
Thank you everyone
28th May 2007, 11:46 #6
- Join Date
- Mar 2006
- Posts
- 86
- Helped
- 11 / 11
- Points
- 1,798
- Level
- 9
it's the VCO running stand alone ( not in closed loop with a PLL )
30th May 2007, 16:25 #7
The VCO is not in PLL closed loop, I think.
Advertisement
1st April 2008, 10:22 #8
- Join Date
- Feb 2008
- Location
- China
- Posts
- 403
- Helped
- 55 / 55
- Points
- 3,875
- Level
- 14
Originally Posted by ilovebow
Please login
