+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Junior Member level 2
    Points: 1,093, Level: 7
    Join Date
    Apr 2007
    Posts
    22
    Points
    1,093
    Level
    7
    free running vco
    Anyone give some explaination.
    Thanks .
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 15,234, Level: 29
    khouly's Avatar
    Join Date
    Oct 2003
    EGYPT
    Posts
    2,368
    Points
    15,234
    Level
    29
    give the meaning of vco
    this is the frequency , which will be out of the VCO without applying the control voltage ,
    khouly
    •   AltAdvertisement
  3. #3
    Member level 1
    Points: 1,961, Level: 10
    Achievements:
    7 years registered
    Join Date
    Apr 2006
    Posts
    35
    Points
    1,961
    Level
    10
    free running vco vs. locked vco
    It's the frequency of the VCO outside of a PLL, yes I agree, it is the oscillation frequency when there is not a control voltage.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Points: 15,926, Level: 30
    E-design's Avatar
    Join Date
    Jun 2002
    Posts
    2,014
    Points
    15,926
    Level
    30
    Re: What's VCO free-running meaning ?
    VCO can have a control voltage and still be un-locked. Steering a VCO with a voltage from say a variable bench PSU does not make it locked. I would say free-running is anything outside the closed PLL loop. A loop can be opened and the control voltage can go either pin high or low, depending on the design.
    Wording from a patent document
    BACKGROUND OF THE INVENTION
    Electronic devices such as RF (Radio Frequency) receivers, transmitters and various other devices include a VCO operating within a PLL (Phase Locked Loop) to maintain a desired oscillation frequency.
    It is conventional practice to tune a VCO to a particular initial frequency before it leaves its factory. This is typically accomplished by using factory equipment to measure the frequency of the VCO while it is free-running (i.e., the PLL is opened),
  5. #5
    Join Date
    Apr 2007
    Posts
    22
    Points
    1,093
    Level
    7
    Thank you everyone
    •   AltAdvertisement
  6. #6
    Member level 5
    Points: 1,798, Level: 9
    Join Date
    Mar 2006
    Posts
    86
    Points
    1,798
    Level
    9
    it's the VCO running stand alone ( not in closed loop with a PLL )
  7. #7
    Full Member level 1
    Points: 3,078, Level: 13
    Join Date
    Apr 2004
    China
    Posts
    101
    Points
    3,078
    Level
    13
    The VCO is not in PLL closed loop, I think.
  8. #8
    Advanced Member level 1
    Points: 3,875, Level: 14
    jecyhale's Avatar
    Join Date
    Feb 2008
    China
    Posts
    403
    Points
    3,875
    Level
    14
    Quote Originally Posted by ilovebow
    Thanks .
    it means VCO runs without PLL.
