read in design
set input constraints like drive strength and arrival time.
set output constraints like load and output delay times.
define all clocks
define any false path and multi-cycle path in the design.
set clock skew and jitter tolerances.
define all input/output timing relationships between clock and ports
then use write sdc command
If you dont setup your design, the sdc output is not going to be correct.
