Question about total GM in single-end and differential op-amps
super
Full Member level 2
Dear all :
I have some question about total GM in
single-end and Differential OPAMP.
The single-end and Differential GM are all gm1, am I right ?
Thanks .
about total GM
That's right
about total GM
yes you are right,
GM of the opamp normally refers to input stage.
about total GM
yes,you can get the GM if the voltage gain is devided by the output resistance.
about total GM
TOTAL GM WILL BE CHANGE IN OUTPUT CURRENT/CHANGE IN I/P VOLTAGE
about total GM
The first one is correct, however,
for the second one, the total GM is
just HALF of gm1,2.
about total GM
Pls check sec 4.2.2 in Razavi for more detail.
The 2nd ckt has GM=gm1 only if the differential input signal is small.
about total GM
Dear gte582w :
why for the second one GM=1/2gm1 ?
total gain = Gm*Rout
=gm1*Rout
I sim AC/Trans are all show me the
=gm1*Rout
= 20log(vop-von)/(vip-vin)
Could you explain it for me ?
thanks.
