Where to find a ByteblasterII schematic?
leonqin
Full Member level 4
China
I request it on altera'MySupport,and they told me that they don't provide .
byteblaster ii schematics lpt
If byteblaster MV is ok
I have it
modify byteblastermv to byteblaster ii
ByteBlasterMV don't suppurt EPCS
byteblastermv sch
Hello
This is schema of BBII. I tested it with Cyclone and EPS1
byteblasterii
mhmhmh
,you try it with Quartussii?
bbmv jtag circuit
Hello
Yes, it works for me with QII 2.2sp2 full and some web
bbii jtag circuit
Have anyone try Quartus 3.0 used byteblaster II?
byteblaster eagle
wpwang said:
Have anyone try qu@rtus 3.0 used byteblaster II?
Good question. I will try it with ByteBlasterMV.
it does work with qu@rtus 3.0 and byteblaster II. you can try it.
ByteBlaster II for Cyclone Serial Configuration
mhmhmh said:
Hello
This Design looks very familiar. It uses a 74HC244 like the ByteBlasterMV. Just uses two of them. You need two?
You tested it with the EPCS1SI8 ? Sure? And it realy works? Realy?
Why should I spend 150,- EUR for a little tiny 74HC244?
The Design of "grivin" **broken link removed**
looks much more complicated! Especialy the "Switches" are IMHO not very cute.
Re: ByteblasterII sch?
mhmhmh's solution is correct. It's a simple version BII and can work well. I just use this way. The total cost is only $2.00
But it only support 2.5v/3.3v/5v.
Of course, the official sch from @ltera is very complex. Here is a BII photo
It can support 1.8v and even lower voltage.
BBMV is used for EPC1,EPC2,EPC4..It has only one 74HC244.
BBII is used for EPS1,EPS4.BBII is more complex with some components!
but why i test it and not work?maybe i not do ti right?
Re: ByteBlaster II for Cyclone Serial Configuration
miro said:
mhmhmh said:
Hello
Because it is a 74HC244 handled with love by a 3 Million dollar pick and place machine! (And because you understand that they need to amortize the pick and place machine! lol ! :D
Just used my spare ByteBlasterMV with modification to successfully program an EPCS1 within Quartus II 4.0SP1 (o;
1. Lift pin 19 of hc244 and connect it to GND
2. Lift pin 8 of hc244 and connect it to pin 4 of LPT
3. Lift pin 17 of hc244 and connect it to pin 5 of LPT
4. Cut connection between pin 7/10 of LPT and replace with 6/10 connection
(recognizes ByteBlasterII instead of MV)
5. Pull pin 15 of LPT to GND
6. Connect pin 12 of hc244 to pin 8 of flatcable
7. Connect pin 3 of hc244 to pin 6 of flatcable
that's all (o;
ByteblasterII sch?
just looking for BBII.thank you all of then, i'll try.
Dear davorin,
you described a way to modify ByteblasterMV to ByteblasterII. Should below circuit then work?
Did anybody use this circuit to programm an EPCS16?
Regards,
ep20k
although the discussion is somewhat outdated, I want to supply my Byteblaster II compatible design, that some customers and I have used since years. Gerber Files and *.gwk for a eightfold PCB are included. If someone could use the original Integra Station design, please send P.M. I also have a Lattice ISP variant of the cable. 2 layer PCB uses industry standards 6 mils (0,15 mm) technology with 12 mils (0,3 mm) vias.
The PCB is intended to fit a Sub-D 25 case with edge mounted Sub-D and 10-pin connector, for the 10-pin connector a cutout is necessary. It looks very similar to the $19 cable presented in a usergroup. In a laboratory enviroment, it could be used without a case as well.
As an additional remark: JTAG programming is operational with long flat cables (1 m and more), AS programming could be an issue with more than 20 cm. Thus it's good to have detachable cables.
Regards,
Frank
