wonka
Hello,
I wrote a Testbenches as P.S show,
And I got some warning in ModelSim:
Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).
Although I know this warning do not affect the TestBench work, I still try to know, how to set a std_logic value for output pin which initialization?
as you can see in my Testbench, I set 'U' for some output pin in the begining, is it right?
P.S
entity rec_tb is
end rec_tb;
-- testbench for BER receiver
library IEEE;
use IEEE.std_logic_1164.all;
architecture stimulus of rec_tb is
-- import component
component seq_rec
port (RXclk :in std_logic;
RXenb :in std_logic;
RXdata :in std_logic;
ERRpulse ut std_logic;
D0 ut std_logic;
D1 ut std_logic;
D2 ut std_logic;
D3 ut std_logic;
D4 ut std_logic;
D5 ut std_logic;
D6 ut std_logic;
D7 ut std_logic;
RXsync ut std_logic);
end component;
-- declare signal
signal CE :std_logic;
signal RXclk :std_logic;
signal RXenb :std_logic;
signal RXdata :std_logic;
signal ERRpulse :std_logic;
signal D0 :std_logic;
signal D1 :std_logic;
signal D2 :std_logic;
signal D3 :std_logic;
signal D4 :std_logic;
signal D5 :std_logic;
signal D6 :std_logic;
signal D7 :std_logic;
signal RXsync :std_logic;
type test_record_t is record
CE :std_logic; -- clock enable
RXenb :std_logic;
RXdata :std_logic;
D0 :std_logic;
D1 :std_logic;
D2 :std_logic;
D3 :std_logic;
D4 :std_logic;
D5 :std_logic;
D6 :std_logic;
D7 :std_logic;
RXsync :std_logic;
end record;
type test_array_t is array(positive range <>) of test_record_t;
-- The following constant declaration describes the vector
constant test_patterns : test_array_t := (
-- CE, RXenb, RXdata, ERRpulse, D0, D1, D2, D3, D4, D5, D6, D7, RXsync
('1', '1', '0', 'U', 'U', 'U', 'U','U','U','U','U','U','U'),
('1', '1', '1', 'U', 'U', 'U', 'U','U','U','U','U','U','U'),
('1', '1', '1', 'U', 'U', 'U', 'U','U','U','U','U','U','U'), -- 64 bits channel Sieze
('1', '1', '1', 'U', 'U', 'U', 'U','U','U','U','U','U','U'), -- system idetifne code
('1', '1', '0', '0', '0', '0', '0','0','0','0','0','0','1'), -- Frequency Hopping code
('1', '1', '1', '0', '0', '0', '0','0','0','0','0','0','1'),
('1', '1', '0', '0', '0', '0', '0','0','0','0','0','0','1') -- fist segment of test
sequence
-- convert a std_logic value to a character
type stdlogic_to_char_t is array(std_logic) of character;
constant to_char : stdlogic_to_char_t := (
'U' => 'U',
'X' => 'X',
'0' => '0',
'1' => '1',
'Z' => 'Z',
'W' => 'W',
'L' => 'L',
'H' => 'H',
begin
-- instantiate the component
uut: seq_rec port map(RXclk,
RXenb,
RXdata,
ERRpulse,
D0,
D1,
D2,
D3,
D4,
D5,
D6,
D7,
RXsync);
-- provide stimulus and check the result
test: process
variable vector : test_record_t;
variable found_error : boolean := false;
begin
for i in test_patterns'range loop
vector := test_patterns(i);
-- apply the stimuls
CE <= vector.CE;
RXenb <= vector.RXenb;
RXdata <= vector.RXdata;
ERRpulse <= vector.ERRpulse;
D0 <= vector.D0;
D1 <= vector.D1;
D2 <= vector.D2;
D3 <= vector.D3;
D4 <= vector.D4;
D5 <= vector.D5;
D6 <= vector.D6;
D7 <= vector.D7;
RXsync <= vector.RXsync;
-- clock (low-high-low) # fist method
RXclk <= '0';
wait for 217 ns;
if CE = '1' then
RXclk <= '1';
end if;
wait for 434 ns;
RXclk <= '0';
wait for 217 ns;
-- check the results of ERRpulse
if (ERRpulse /= vector.ERRpulse) then
assert false
report "ERRpulse is " & to_char(ERRpulse)
& ". Expected " & to_char(vector.ERRpulse);
found_error := true;
end if;
-- check the results of D0
if (D0 /= vector.D0) then
assert false
report "D0 is " & to_char(D0) & ". "
& "Expected value is " & to_char(vector.D0);
end if;
-- check the results of D1
if (D1 /= vector.D1) then
assert false
report "D1 is " & to_char(D1) & ". "
& "Expected value is " & to_char(vector.D1);
end if;
-- check the results of D2
if (D2 /= vector.D2) then
assert false
report "D2 is " & to_char(D2) & ". "
& "Expected value is " & to_char(vector.D2);
end if;
-- check the results of D3
if (D1 /= vector.D3) then
assert false
report "D3 is " & to_char(D3) & ". "
& "Expected value is " & to_char(vector.D3);
end if;
-- check the results of D4
if (D4 /= vector.D4) then
assert false
report "D4 is " & to_char(D4) & ". "
& "Expected value is " & to_char(vector.D4);
end if;
-- check the results of D5
if (D5 /= vector.D1) then
assert false
report "D5 is " & to_char(D5) & ". "
& "Expected value is " & to_char(vector.D5);
end if;
-- check the results of D6
if (D6 /= vector.D6) then
assert false
report "D6 is " & to_char(D6) & ". "
& "Expected value is " & to_char(vector.D6);
end if;
-- check the results of D7
if (D7 /= vector.D7) then
assert false
report "D7 is " & to_char(D7) & ". "
& "Expected value is " & to_char(vector.D7);
end if;
if (RXsync /= vector.RXsync) then
assert false
report "RXsync is " & to_char(RXsync) & ". "
& "Expected value is " & to_char(vector.RXsync);
end if;
end loop;
assert not found_error
report "There were ERRORS in the test."
severity note;
assert found_error
report "Test completed with no errors."
severity note;
wait;
end process;
end stimulus;
P.S
entity rec_tb is
end rec_tb;
library IEEE;
-- import component
component seq_rec
D0 ut std_logic;
D1 ut std_logic;
D2 ut std_logic;
D3 ut std_logic;
D4 ut std_logic;
D5 ut std_logic;
D6 ut std_logic;
D7 ut std_logic;
end component;
-- declare signal
RXenb :std_logic;
RXdata :std_logic;
D0 :std_logic;
D1 :std_logic;
D2 :std_logic;
D3 :std_logic;
D4 :std_logic;
D5 :std_logic;
D6 :std_logic;
D7 :std_logic;
RXsync :std_logic;
end record;
sequence
'U' => 'U',
'X' => 'X',
'0' => '0',
'1' => '1',
'Z' => 'Z',
'W' => 'W',
'L' => 'L',
'H' => 'H',
begin
RXenb,
RXdata,
ERRpulse,
D0,
D1,
D2,
D3,
D4,
D5,
D6,
D7,
RXsync);
test: process
begin
CE <= vector.CE;
D0 <= vector.D0;
D1 <= vector.D1;
D2 <= vector.D2;
D3 <= vector.D3;
D4 <= vector.D4;
D5 <= vector.D5;
D6 <= vector.D6;
D7 <= vector.D7;
RXclk <= '0';
wait for 217 ns;
if CE = '1' then
RXclk <= '1';
end if;
wait for 434 ns;
RXclk <= '0';
wait for 217 ns;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
assert false
end if;
end loop;
severity note;
assert found_error
severity note;
wait;
end process;
end stimulus;
