+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Full Member level 4
    Points: 2,910, Level: 12
    Join Date
    Feb 2005
    Posts
    195
    Points
    2,910
    Level
    12
    hfss differential pair
    Hi, everyone. I have a question about the differential pair definition in HFSS Driven Terminal simulation.
    I am wondering is the Differential Terminal Port Impedance equal to the odd impedance and the common terminal port impedance equal to the even mode impedance in the couple line.
    Actually, from the manual of the HFSS chap. 8: signal integrity example, it defines two edge coupled stripline and assign two terminal line in one waveport. And then the differential pair is assigned.
    However, the simulation results show that the differential impedance is 116.76 Ohm but the common one is 32.61 Ohm. It contradicts to my knowledge that the even mode impedance should always larger than the odd one.
    Thanks.
    •   AltAdvertisment
  2. #2
    Member level 2
    Points: 1,482, Level: 8
    Join Date
    Aug 2006
    Posts
    43
    Points
    1,482
    Level
    8
    differential pair
    Hi, winglj
    Based on my knowledge, the differential terminal port impedance should be twice the odd impedance while the common terminal port impedance half the even impedance. Because the even and odd impedance is defined on single microstrip line while the differntial and common impedance is defined on coupled lines.
    2 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Full Member level 4
    Points: 2,398, Level: 11
    dingjingfeng's Avatar
    Join Date
    Aug 2005
    Posts
    190
    Points
    2,398
    Level
    11
    simulate odd and common port
    impedance
    odd = sqrt(L/(Cgnd/2+2*Cgap))
    even = sqrt(L/C/2)
    differential impedance should be much smaller than the common mode impedance
    the smaller the gap the larger difference
    •   AltAdvertisment
  4. #4
    Member level 1
    Points: 5,241, Level: 17
    Join Date
    Nov 2006
    Posts
    36
    Points
    5,241
    Level
    17
    differential pair port impedance
  5. #5
    Junior Member level 2
    Points: 1,758, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    23
    Points
    1,758
    Level
    9
    terminal mode hfss
    Terminal mode Excitation is iner of Antenna but Driven Terminal is outer of Antenna.
    At transmision line Tow port required and but in Antenna is one Exitation port.
