Hspice convergent problem ? Help needed ....
wls
Member level 4
Singapore
kcl test failure hspice
Hello Guys . Need help , I am running hspice to a 8 bit ADC SAR and have convergent problem ? How to solve it ?
Regards.
.OPTION numdgt=10
.option converge=1
.temp 25
*.tran 0.1us 2.304ms
*.tran 0.1us 500us
.tran 0.2us 20us
hspice diagnostic for nonconvergent nodes and elements
node subcircuit old new error
name definition voltage voltage tolerance
(net12) main_ckt -6.002m -6.136m 2.381
total voltage source power dissipation= 1.0890x watts
**** diodes
**** jfets
**** jfets
**** mosfets
***** job aborted
.option numdgt=10
****** job statistics summary tnom= 25.000 temp= 25.000
total memory used 11241 kbytes
# nodes = 786 # elements= 1677
# diodes= 3 # bjts = 0 # jfets = 2 # mosfets = 1560 # va device = 0
analysis time # points tot. iter conv.iter
op point 11.42 1 1096
transient 80.12 101 5762 2112 rev= 606
readin 0.10
errchk 0.15
setup 0.03
output 0.03
total cpu time 91.86 seconds
job started at 08:18:28 02/28/2007
job ended at 08:20:01 02/28/2007
>error ***** hspice job aborted
Init: hspice initialization file: /applp/synopsys/hs2006.03/hspice/hspice.ini
lic: Release hspice token(s)
Try to check your W,L with Model technic!
you can try some different start time.
for example,".tran 0.21us 20us"
yes,reset the simulation time
hi,
try this:
.option itl4=100
or you can add some initial condition,such as use
.ic command
or change the vdd into a pwl voltage source.
good luck
jeff
did you try ".OPTION DCSTEP " for DC convergence?
Hello . I tried using the option "converge=4 plus itl4=100" and get nonconvergent message as below . I paste the .ic0 below also . Can u guys guide how to use the ".ic / DCSTEP / .NODESET " with the .ic0 . I am quite new to hspice ?
Thx in advance .
.option post = 2
.option itl4=100
.option converge=4
(xadc8.xi0.xi0.net22) cfg2 -253.712m -254.249m 1.763
hspice diagnostic for kcl test failure
node subcircuit sum of error
name definition currents tolerance
**** diodes
**** mosfets
***** job aborted
1 ****** HSPICE X-2005.09-SP1 (20051124) 10:38:06 03/05/2007 pcnt
*.option numdgt=10
total memory used 11510 kbytes
# nodes = 789 # elements= 1677
# diodes= 3 # bjts = 0 # jfets = 0 # mosfets = 1560 # va device = 0
op point 7.10 1 539
transient 229.51 79 13955 2120 rev= 565
readin 0.19
errchk 0.15
setup 0.11
output 0.05
total cpu time 237.15 seconds
job started at 10:38:06 03/05/2007
job ended at 10:42:13 03/05/2007
* "simulator" "HSPICE"
* "version" "X-2005.09-SP1 "
* "format" "HSP"
* "rundate" "10:38:06 03/05/2007"
* "netlist" "d:\misc2007\2007hspicesimulation\sar8latest.sp "
* "runtitle" "*.option numdgt=10 "
* time = 0.
* temperature = 25.0000
*** BEGIN: Saved Operating Point ***
.option
+ gmindc= 1.0000p
.nodeset
+ clock = 0.
+ comp = 3.3000
+ d0 = 3.3000
+ d1 = 3.3000
+ d2 = 1.4429
+ d3 = 1.4429
+ d4 = 1.4429
+ d5 = 1.4429
+ d6 = 3.3000
+ d7 = 3.3000
+ dac<0> = 3.3000
+ dac<1> = 12.7768n
+ dac<2> = 12.7768n
+ dac<3> = 12.7768n
+ dac<4> = 12.7768n
+ dac<5> = 12.7768n
+ dac<6> = 12.7768n
+ dac<7> = 12.7768n
+ eoc = 23.2609n
+ net1 = 3.3000
+ net12 = 5.5914n
+ net37 = 5.5914n
+ net6 = 3.3000
+ sample = 3.3000
+ start = 0.
+ vdac = 11.6668m
+ vdda = 3.3000
+ vin = 0.
+ vout = 2.8357
+ vout2 = 12.8939m
+ vrn = 0.
+ vrp = 3.3000
+ vssa = 0.
+ xbitdac.100 = 1.6500
+ xbitdac.b0l = 999.9990m
+ xbitdac.b1l = 999.9990m
+ xbitdac.b2l = 416.3051m
+ xbitdac.b3l = 416.3051m
+ xbitdac.b4l = 416.3051m
+ xbitdac.b5l = 416.3051m
+ xbitdac.b6l = 999.9990m
+ xbitdac.b7l = 999.9990m
+ xbitdac2.100 = 1.6500
+ xbitdac2.b0l = 999.9990m
+ xbitdac2.b1l = 999.9990n
+ xbitdac2.b2l = 999.9990n
+ xbitdac2.b3l = 999.9990n
+ xbitdac2.b4l = 999.9990n
+ xbitdac2.b5l = 999.9990n
+ xbitdac2.b6l = 999.9990n
+ xbitdac2.b7l = 999.9990n
+ xadc8.xi2.gndaint = 1.2111n
+ xadc8.xi2.net10671 = 3.3000
+ xadc8.xi2.net10676 = 3.3000
+ xadc8.xi2.net10681 = 3.3000
+ xadc8.xi2.net10686 = 3.3000
+ xadc8.xi2.net10691 = 3.3000
+ xadc8.xi2.net10696 = 3.3000
+ xadc8.xi2.net10701 = 3.3000
+ xadc8.xi2.net10706 = 3.3000
+ xadc8.xi2.net10711 = 3.3000
+ xadc8.xi2.net10716 = 3.3000
+ xadc8.xi2.net10721 = 3.3000
+ xadc8.xi2.net10726 = 3.3000
+ xadc8.xi2.net10731 = 3.3000
+ xadc8.xi2.net10736 = 3.3000
+ xadc8.xi2.net10741 = 63.2411n
+ xadc8.xi2.net10838 = 14.2985n
+ xadc8.xi2.net10840 = 14.2985n
+ xadc8.xi2.net10842 = 14.2985n
+ xadc8.xi2.net10844 = 14.2985n
+ xadc8.xi2.net10846 = 14.2985n
+ xadc8.xi2.net10848 = 14.2985n
+ xadc8.xi2.net10850 = 14.2985n
+ xadc8.xi2.net10852 = 14.2985n
+ xadc8.xi2.net10854 = 14.2985n
+ xadc8.xi2.net10856 = 14.2985n
+ xadc8.xi2.net10858 = 14.2985n
+ xadc8.xi2.net10860 = 14.2985n
+ xadc8.xi2.net10862 = 14.2985n
+ xadc8.xi2.net10864 = 14.2985n
+ xadc8.xi2.net10866 = 3.3000
+ xadc8.xi2.net10868 = 3.3000
+ xadc8.xi2.net10870 = 14.3549n
+ xadc8.xi2.net10872 = 14.3549n
+ xadc8.xi2.net10874 = 14.3549n
+ xadc8.xi2.net10876 = 3.3000
+ xadc8.xi2.net10880 = 3.3000
+ xadc8.xi2.net10882 = 3.3000
+ xadc8.xi2.net11013 = 3.3000
+ xadc8.xi2.net11348 = 105.1284m
+ xadc8.xi2.net11366 = 116.8279m
+ xadc8.xi2.net11369 = 163.6644m
+ xadc8.xi2.net11387 = 175.3833m
+ xadc8.xi2.net11389 = 13.0415m
+ xadc8.xi2.net11392 = 35.0101m
+ xadc8.xi2.net11395 = 83.1379m
+ xadc8.xi2.net11401 = 59.7576m
+ xadc8.xi2.net11407 = 153.3700m
+ xadc8.xi2.net11410 = 141.6550m
+ xadc8.xi2.net11416 = 48.0731m
+ xadc8.xi2.net11425 = 71.4459m
+ xadc8.xi2.net11436 = 14.2985n
+ xadc8.xi2.net11494 = 129.9439m
+ xadc8.xi2.net126 = 1.6398
+ xadc8.xi2.net159 = 809.6866m
+ xadc8.xi2.net17156 = 14.3549n
+ xadc8.xi2.net178 = 1.8473
+ xadc8.xi2.net187 = 2.4699
+ xadc8.xi2.net190 = 2.6774
+ xadc8.xi2.net196 = 2.8849
+ xadc8.xi2.net199 = 1.2247
+ xadc8.xi2.net211 = 602.1609m
+ xadc8.xi2.net3058 = 36.3922m
+ xadc8.xi2.net3096 = 187.1096m
+ xadc8.xi2.net3108 = 1.0172
+ xadc8.xi2.net3123 = 394.6353m
+ xadc8.xi2.net3142 = 94.8337m
+ xadc8.xi2.net3144 = 3.0925
+ xadc8.xi2.net3150 = 2.2624
+ xadc8.xi2.net3183 = 2.0548
+ xadc8.xi2.net3189 = 1.4323
+ xadc8.xi2.net362 = 11.6667m
+ xadc8.xi2.net366 = 140.2384m
+ xadc8.xi2.net3954 = 14.3549n
+ xadc8.xi2.net3955 = 14.3549n
+ xadc8.xi2.net3956 = 14.3549n
+ xadc8.xi2.net3958 = 14.3549n
+ xadc8.xi2.net3992 = 14.2985n
+ xadc8.xi2.net3995 = 3.3000
+ xadc8.xi2.net4001 = 14.2985n
+ xadc8.xi2.net4007 = 14.2985n
+ xadc8.xi2.net4010 = 14.2985n
+ xadc8.xi2.net4013 = 14.2985n
+ xadc8.xi2.net4025 = 14.2985n
+ xadc8.xi2.net4031 = 14.2985n
+ xadc8.xi2.net4037 = 14.2985n
+ xadc8.xi2.net4046 = 14.2985n
+ xadc8.xi2.net4061 = 14.2985n
+ xadc8.xi2.net4064 = 14.2985n
+ xadc8.xi2.net4067 = 14.2985n
+ xadc8.xi2.net4070 = 14.2985n
+ xadc8.xi2.net4166 = 14.2985n
+ xadc8.xi2.net4184 = 14.2985n
+ xadc8.xi2.net4289 = 3.3000
+ xadc8.xi2.net429 = 118.2367m
+ xadc8.xi2.net4292 = 3.3000
+ xadc8.xi2.net4298 = 3.3000
+ xadc8.xi2.net4301 = 78.0050n
+ xadc8.xi2.net4302 = 185.6776m
+ xadc8.xi2.net4304 = 3.3000
+ xadc8.xi2.net4307 = 3.3000
+ xadc8.xi2.net4310 = 3.3000
+ xadc8.xi2.net4319 = 3.3000
+ xadc8.xi2.net4325 = 3.3000
+ xadc8.xi2.net4328 = 3.3000
+ xadc8.xi2.net4346 = 3.3000
+ xadc8.xi2.net4364 = 3.3000
+ xadc8.xi2.net4367 = 3.3000
+ xadc8.xi2.net4370 = 3.3000
+ xadc8.xi2.net4373 = 3.3000
+ xadc8.xi2.net4379 = 3.3000
+ xadc8.xi2.net438 = 151.9495m
+ xadc8.xi2.net442 = 46.6872m
+ xadc8.xi2.net445 = 165.0889m
+ xadc8.xi2.net450 = 81.7407m
+ xadc8.xi2.net454 = 58.3680m
+ xadc8.xi2.net457 = 106.5333m
+ xadc8.xi2.net470 = 70.0525m
+ xadc8.xi2.net473 = 24.7150m
+ xadc8.xi2.net474 = 23.3366m
+ xadc8.xi2.net526 = 128.5312m
+ xadc8.xi2.net5948 = 3.3000
+ xadc8.xi2.net5950 = 3.3000
+ xadc8.xi2.net5952 = 3.3000
+ xadc8.xi2.net5954 = 3.3000
+ xadc8.xi2.net634 = 93.4327m
+ xadc8.xi2.net9 = 1.3712m
+ xadc8.xi2.vddint = 3.3000
+ xadc8.xi1.i<0> = 3.3000
+ xadc8.xi1.i<1> = 3.3000
+ xadc8.xi1.i<2> = 3.3000
+ xadc8.xi1.n243 = 23.2609n
+ xadc8.xi1.n25 = 12.7768n
+ xadc8.xi1.n26 = 12.7768n
+ xadc8.xi1.n261 = 32.3080n
+ xadc8.xi1.n262 = 32.3080n
+ xadc8.xi1.n263 = 32.3080n
+ xadc8.xi1.n264 = 32.3080n
+ xadc8.xi1.n265 = 32.3080n
+ xadc8.xi1.n266 = 32.3379n
+ xadc8.xi1.n267 = 32.3080n
+ xadc8.xi1.n268 = 32.3080n
+ xadc8.xi1.n269 = 44.5071n
+ xadc8.xi1.n27 = 12.7768n
+ xadc8.xi1.n270 = 44.5071n
+ xadc8.xi1.n271 = 32.3080n
+ xadc8.xi1.n272 = 32.3080n
+ xadc8.xi1.n273 = 49.3205n
+ xadc8.xi1.n274 = 81.7034n
+ xadc8.xi1.n275 = 25.3073n
+ xadc8.xi1.n276 = 3.3000
+ xadc8.xi1.n28 = 3.3000
+ xadc8.xi1.n282 = 3.3000
+ xadc8.xi1.n284 = 3.3000
+ xadc8.xi1.n285 = 47.5336n
+ xadc8.xi1.n286 = 3.3000
+ xadc8.xi1.n29 = 12.7768n
+ xadc8.xi1.n30 = 3.3000
+ xadc8.xi1.n31 = 3.3000
+ xadc8.xi1.n32 = 36.0101n
+ xadc8.xi1.n33 = 3.3000
+ xadc8.xi1.n34 = 3.3000
+ xadc8.xi1.n35 = 3.3000
+ xadc8.xi1.n36 = 3.3000
+ xadc8.xi1.n368 = 2.4884n
+ xadc8.xi1.n37 = 3.3000
+ xadc8.xi1.n38 = 3.3000
+ xadc8.xi1.n39 = 3.3000
+ xadc8.xi1.n40 = 3.3000
+ xadc8.xi1.n41 = 3.3000
+ xadc8.xi1.n42 = 3.3000
+ xadc8.xi1.n43 = 3.3000
+ xadc8.xi1.n44 = 3.3000
+ xadc8.xi1.n45 = 3.3000
+ xadc8.xi1.n46 = 65.1132n
+ xadc8.xi1.n47 = 25.3073n
+ xadc8.xi1.n48 = 3.3000
+ xadc8.xi1.n49 = 3.3000
+ xadc8.xi1.n50 = 3.3000
+ xadc8.xi1.n51 = 47.5336n
+ xadc8.xi1.n52 = 3.3000
+ xadc8.xi1.n53 = 3.3000
+ xadc8.xi1.n54 = 3.3000
+ xadc8.xi1.n55 = 3.3000
+ xadc8.xi1.n56 = 23.2609n
+ xadc8.xi1.n57 = 5.7840n
+ xadc8.xi1.n58 = 25.3073n
+ xadc8.xi1.n59 = 25.3073n
+ xadc8.xi1.n60 = 3.3000
+ xadc8.xi1.n61 = 12.7768n
+ xadc8.xi1.n62 = 0.
+ xadc8.xi1.n63 = 3.3000
+ xadc8.xi1.net0774 = 32.3080n
+ xadc8.xi1.net0947 = 25.3073n
+ xadc8.xi1.net790 = 12.7768n
+ xadc8.xi1.net795 = 1.4429
+ xadc8.xi1.net800 = 1.4429
+ xadc8.xi1.net805 = 12.7768n
+ xadc8.xi1.net810 = 12.7768n
+ xadc8.xi1.net815 = 1.4429
+ xadc8.xi1.net820 = 1.4429
+ xadc8.xi1.net825 = 12.7768n
+ xadc8.xi1.net831 = 3.3000
+ xadc8.xi1.net837 = 3.3000
+ xadc8.xi1.net843 = 3.3000
+ xadc8.xi1.net849 = 3.3000
+ xadc8.xi1.net861 = 3.3000
+ xadc8.xi1.net867 = 3.3000
+ xadc8.xi1.net873 = 3.3000
+ xadc8.xi1.net895 = 12.7768n
+ xadc8.xi1.net907 = 12.7768n
+ xadc8.xi0.net21 = 8.8591n
+ xadc8.xi0.net23 = 1.6420
+ xadc8.xi0.net32 = 1.6420
+ xadc8.xi0.net36 = 1.6420
+ xadc8.xi0.net40 = 1.6420
+ xbitdac.x7.one = 1.0000
+ xbitdac.x6.one = 1.0000
+ xbitdac.x5.one = 1.0000
+ xbitdac.x4.one = 1.0000
+ xbitdac.x3.one = 1.0000
+ xbitdac.x2.one = 1.0000
+ xbitdac.x1.one = 1.0000
+ xbitdac.x0.one = 1.0000
+ xbitdac2.x7.one = 1.0000
+ xbitdac2.x6.one = 1.0000
+ xbitdac2.x5.one = 1.0000
+ xbitdac2.x4.one = 1.0000
+ xbitdac2.x3.one = 1.0000
+ xbitdac2.x2.one = 1.0000
+ xbitdac2.x1.one = 1.0000
+ xbitdac2.x0.one = 1.0000
+ xadc8.xi2.xi717.net13 = 42.1607n
+ xadc8.xi2.xi717.net23 = 21.0804n
+ xadc8.xi2.xi728.net13 = 559.0584m
+ xadc8.xi2.xi728.net23 = 559.0584m
+ xadc8.xi2.xi728.net61 = 73.6040m
+ xadc8.xi2.xi745.net13 = 2.6432
+ xadc8.xi2.xi745.net23 = 2.6249
+ xadc8.xi2.xi745.net61 = 557.9618m
+ xadc8.xi2.xi729.net13 = 2.6432
+ xadc8.xi2.xi729.net23 = 2.6249
+ xadc8.xi2.xi729.net61 = 557.9618m
+ xadc8.xi2.xi748.net13 = 874.4747m
+ xadc8.xi2.xi748.net23 = 198.0304m
+ xadc8.xi2.xi748.net61 = 26.4218m
+ xadc8.xi2.xi747.net13 = 2.6573
+ xadc8.xi2.xi747.net23 = 687.4512m
+ xadc8.xi2.xi747.net61 = 99.5451m
+ xadc8.xi2.xi718.net13 = 719.5600m
+ xadc8.xi2.xi718.net23 = 1.2907n
+ xadc8.xi2.xi718.net61 = 645.3603p
+ xadc8.xi2.xi734.net13 = 7.1324n
+ xadc8.xi2.xi734.net23 = 4.7549n
+ xadc8.xi2.xi734.net61 = 2.3775n
+ xadc8.xi2.xi740.net13 = 859.1136m
+ xadc8.xi2.xi740.net23 = 138.0121m
+ xadc8.xi2.xi740.net61 = 252.5501p
+ xadc8.xi2.xi743.net13 = 2.6562
+ xadc8.xi2.xi743.net23 = 382.5616m
+ xadc8.xi2.xi743.net61 = 382.5616m
+ xadc8.xi2.xi737.net13 = 2.6407
+ xadc8.xi2.xi737.net23 = 2.6216
+ xadc8.xi2.xi737.net61 = 1.9071n
+ xadc8.xi2.xi738.net13 = 486.6419m
+ xadc8.xi2.xi738.net23 = 486.6419m
+ xadc8.xi2.xi738.net61 = 490.1275p
+ xadc8.xi2.xi744.net13 = 845.9963m
+ xadc8.xi2.xi744.net23 = 93.6138m
+ xadc8.xi2.xi744.net61 = 93.6138m
+ xadc8.xi2.xi735.net13 = 2.6526
+ xadc8.xi2.xi735.net23 = 3.8558n
+ xadc8.xi2.xi735.net61 = 1.9279n
+ xadc8.xi2.xi736.net13 = 719.5600m
+ xadc8.xi2.xi736.net23 = 1.2907n
+ xadc8.xi2.xi736.net61 = 645.3603p
+ xadc8.xi2.xi733.net13 = 58.5037n
+ xadc8.xi2.xi733.net23 = 39.0025n
+ xadc8.xi2.xi733.net61 = 19.5012n
+ xadc8.xi2.xi730.net13 = 874.4747m
+ xadc8.xi2.xi730.net23 = 198.0304m
+ xadc8.xi2.xi730.net61 = 26.4218m
+ xadc8.xi2.xi731.net13 = 2.6573
+ xadc8.xi2.xi731.net23 = 687.4512m
+ xadc8.xi2.xi731.net61 = 99.5451m
+ xadc8.xi2.xi724.net13 = 367.7433m
+ xadc8.xi2.xi724.net23 = 367.7433m
+ xadc8.xi2.xi724.net61 = 367.7433m
+ xadc8.xi2.xi725.net13 = 2.6328
+ xadc8.xi2.xi725.net23 = 2.6118
+ xadc8.xi2.xi725.net61 = 2.6039
+ xadc8.xi2.xi720.net13 = 486.6419m
+ xadc8.xi2.xi720.net23 = 486.6419m
+ xadc8.xi2.xi720.net61 = 490.1275p
+ xadc8.xi2.xi723.net13 = 2.6569
+ xadc8.xi2.xi723.net23 = 565.6095m
+ xadc8.xi2.xi723.net61 = 542.8538p
+ xadc8.xi2.xi722.net13 = 859.1136m
+ xadc8.xi2.xi722.net23 = 138.0121m
+ xadc8.xi2.xi722.net61 = 252.5501p
+ xadc8.xi2.xi721.net13 = 2.6407
+ xadc8.xi2.xi721.net23 = 2.6216
+ xadc8.xi2.xi721.net61 = 1.9071n
+ xadc8.xi2.xi719.net13 = 2.6526
+ xadc8.xi2.xi719.net23 = 3.8558n
+ xadc8.xi2.xi719.net61 = 1.9279n
+ xadc8.xi2.xi727.net13 = 2.6562
+ xadc8.xi2.xi727.net23 = 382.5616m
+ xadc8.xi2.xi727.net61 = 382.5616m
+ xadc8.xi2.xi746.net13 = 559.0584m
+ xadc8.xi2.xi746.net23 = 559.0584m
+ xadc8.xi2.xi746.net61 = 73.6040m
+ xadc8.xi2.xi726.net13 = 845.9963m
+ xadc8.xi2.xi726.net23 = 93.6138m
+ xadc8.xi2.xi726.net61 = 93.6138m
+ xadc8.xi2.xi732.net13 = 7.1324n
+ xadc8.xi2.xi732.net23 = 4.7549n
+ xadc8.xi2.xi732.net61 = 2.3775n
+ xadc8.xi2.xi742.net13 = 367.7433m
+ xadc8.xi2.xi742.net23 = 367.7433m
+ xadc8.xi2.xi742.net61 = 367.7433m
+ xadc8.xi2.xi739.net13 = 2.6569
+ xadc8.xi2.xi739.net23 = 565.6095m
+ xadc8.xi2.xi739.net61 = 542.8538p
+ xadc8.xi2.xi741.net13 = 2.6328
+ xadc8.xi2.xi741.net23 = 2.6118
+ xadc8.xi2.xi741.net61 = 2.6039
+ xadc8.xi2.xi604.net4 = 2.3661
+ xadc8.xi2.xi605.net4 = 2.1586
+ xadc8.xi2.xi606.net4 = 1.9511
+ xadc8.xi2.xi607.net4 = 1.7436
+ xadc8.xi2.xi602.net4 = 2.5737
+ xadc8.xi2.xi601.net4 = 2.7812
+ xadc8.xi2.xi603.net4 = 3.1962
+ xadc8.xi2.xi549.net4 = 913.4494m
+ xadc8.xi2.xi600.net4 = 2.9887
+ xadc8.xi2.xi546.net4 = 498.3981m
+ xadc8.xi2.xi544.net4 = 290.8724m
+ xadc8.xi2.xi550.net4 = 1.1210
+ xadc8.xi2.xi551.net4 = 1.3285
+ xadc8.xi2.xi548.net4 = 1.5360
+ xadc8.xi2.xi545.net4 = 93.5548m
+ xadc8.xi2.xi547.net4 = 705.9238m
+ xadc8.xi1.xu4.net6 = 0.
+ xadc8.xi1.xu5.net6 = 3.3000
+ xadc8.xi1.xout_reg[6.ci = 25.3073n
+ xadc8.xi1.xout_reg[6.cn = 3.3000
+ xadc8.xi1.xout_reg[6.net054 = 91.3851n
+ xadc8.xi1.xout_reg[6.net062 = 3.3000
+ xadc8.xi1.xout_reg[6.net47 = 18.2711n
+ xadc8.xi1.xout_reg[6.net48 = 102.3736n
+ xadc8.xi1.xout_reg[6.net55 = 3.3000
+ xadc8.xi1.xout_reg[6.net57 = 54.8281n
+ xadc8.xi1.xout_reg[6.net63 = 3.3000
+ xadc8.xi1.xout_reg[6.x = 3.3000
+ xadc8.xi1.xout_reg[5.ci = 25.3073n
+ xadc8.xi1.xout_reg[5.cn = 3.3000
+ xadc8.xi1.xout_reg[5.net054 = 1.4429
+ xadc8.xi1.xout_reg[5.net062 = 3.3000
+ xadc8.xi1.xout_reg[5.net47 = 1.4429
+ xadc8.xi1.xout_reg[5.net48 = 1.4429
+ xadc8.xi1.xout_reg[5.net55 = 1.4429
+ xadc8.xi1.xout_reg[5.net57 = 1.4429
+ xadc8.xi1.xout_reg[5.net63 = 1.4429
+ xadc8.xi1.xout_reg[5.x = 1.4429
+ xadc8.xi1.xout_reg[3.ci = 25.3073n
+ xadc8.xi1.xout_reg[3.cn = 3.3000
+ xadc8.xi1.xout_reg[3.net054 = 1.4429
+ xadc8.xi1.xout_reg[3.net062 = 3.3000
+ xadc8.xi1.xout_reg[3.net47 = 1.4429
+ xadc8.xi1.xout_reg[3.net48 = 1.4429
+ xadc8.xi1.xout_reg[3.net55 = 1.4429
+ xadc8.xi1.xout_reg[3.net57 = 1.4429
+ xadc8.xi1.xout_reg[3.net63 = 1.4429
+ xadc8.xi1.xout_reg[3.x = 1.4429
+ xadc8.xi1.xout_reg[7.ci = 25.3073n
+ xadc8.xi1.xout_reg[7.cn = 3.3000
+ xadc8.xi1.xout_reg[7.net054 = 91.3851n
+ xadc8.xi1.xout_reg[7.net062 = 3.3000
+ xadc8.xi1.xout_reg[7.net47 = 18.2711n
+ xadc8.xi1.xout_reg[7.net48 = 102.3736n
+ xadc8.xi1.xout_reg[7.net55 = 3.3000
+ xadc8.xi1.xout_reg[7.net57 = 54.8281n
+ xadc8.xi1.xout_reg[7.net63 = 3.3000
+ xadc8.xi1.xout_reg[7.x = 3.3000
+ xadc8.xi1.xout_reg[0.ci = 25.3073n
+ xadc8.xi1.xout_reg[0.cn = 3.3000
+ xadc8.xi1.xout_reg[0.net054 = 81.6141n
+ xadc8.xi1.xout_reg[0.net062 = 3.3000
+ xadc8.xi1.xout_reg[0.net47 = 18.2711n
+ xadc8.xi1.xout_reg[0.net48 = 92.6025n
+ xadc8.xi1.xout_reg[0.net55 = 3.3000
+ xadc8.xi1.xout_reg[0.net57 = 49.9426n
+ xadc8.xi1.xout_reg[0.net63 = 3.3000
+ xadc8.xi1.xout_reg[0.x = 3.3000
+ xadc8.xi1.xout_reg[4.ci = 25.3073n
+ xadc8.xi1.xout_reg[4.cn = 3.3000
+ xadc8.xi1.xout_reg[4.net054 = 1.4429
+ xadc8.xi1.xout_reg[4.net062 = 3.3000
+ xadc8.xi1.xout_reg[4.net47 = 1.4429
+ xadc8.xi1.xout_reg[4.net48 = 1.4429
+ xadc8.xi1.xout_reg[4.net55 = 1.4429
+ xadc8.xi1.xout_reg[4.net57 = 1.4429
+ xadc8.xi1.xout_reg[4.net63 = 1.4429
+ xadc8.xi1.xout_reg[4.x = 1.4429
+ xadc8.xi1.xout_reg[2.ci = 25.3073n
+ xadc8.xi1.xout_reg[2.cn = 3.3000
+ xadc8.xi1.xout_reg[2.net054 = 1.4429
+ xadc8.xi1.xout_reg[2.net062 = 3.3000
+ xadc8.xi1.xout_reg[2.net47 = 1.4429
+ xadc8.xi1.xout_reg[2.net48 = 1.4429
+ xadc8.xi1.xout_reg[2.net55 = 1.4429
+ xadc8.xi1.xout_reg[2.net57 = 1.4429
+ xadc8.xi1.xout_reg[2.net63 = 1.4429
+ xadc8.xi1.xout_reg[2.x = 1.4429
+ xadc8.xi1.xout_reg[1.ci = 25.3073n
+ xadc8.xi1.xout_reg[1.cn = 3.3000
+ xadc8.xi1.xout_reg[1.net054 = 91.3851n
+ xadc8.xi1.xout_reg[1.net062 = 3.3000
+ xadc8.xi1.xout_reg[1.net47 = 18.2711n
+ xadc8.xi1.xout_reg[1.net48 = 102.3736n
+ xadc8.xi1.xout_reg[1.net55 = 3.3000
+ xadc8.xi1.xout_reg[1.net57 = 54.8281n
+ xadc8.xi1.xout_reg[1.net63 = 3.3000
+ xadc8.xi1.xout_reg[1.x = 3.3000
+ xadc8.xi1.xdac_reg[6.ci = 25.3073n
+ xadc8.xi1.xdac_reg[6.cn = 3.3000
+ xadc8.xi1.xdac_reg[6.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[6.net47 = 3.3000
+ xadc8.xi1.xdac_reg[6.net48 = 3.3000
+ xadc8.xi1.xdac_reg[6.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[6.net57 = 3.3000
+ xadc8.xi1.xdac_reg[6.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[6.net80 = 3.3000
+ xadc8.xi1.xdac_reg[6.net89 = 3.3000
+ xadc8.xi1.xdac_reg[4.ci = 25.3073n
+ xadc8.xi1.xdac_reg[4.cn = 3.3000
+ xadc8.xi1.xdac_reg[4.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[4.net47 = 3.3000
+ xadc8.xi1.xdac_reg[4.net48 = 3.3000
+ xadc8.xi1.xdac_reg[4.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[4.net57 = 3.3000
+ xadc8.xi1.xdac_reg[4.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[4.net80 = 3.3000
+ xadc8.xi1.xdac_reg[4.net89 = 3.3000
+ xadc8.xi1.xdac_reg[7.ci = 25.3073n
+ xadc8.xi1.xdac_reg[7.cn = 3.3000
+ xadc8.xi1.xdac_reg[7.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[7.net47 = 3.3000
+ xadc8.xi1.xdac_reg[7.net48 = 3.3000
+ xadc8.xi1.xdac_reg[7.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[7.net57 = 3.3000
+ xadc8.xi1.xdac_reg[7.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[7.net80 = 3.3000
+ xadc8.xi1.xdac_reg[7.net89 = 3.3000
+ xadc8.xi1.xdac_reg[2.ci = 25.3073n
+ xadc8.xi1.xdac_reg[2.cn = 3.3000
+ xadc8.xi1.xdac_reg[2.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[2.net47 = 3.3000
+ xadc8.xi1.xdac_reg[2.net48 = 3.3000
+ xadc8.xi1.xdac_reg[2.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[2.net57 = 3.3000
+ xadc8.xi1.xdac_reg[2.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[2.net80 = 3.3000
+ xadc8.xi1.xdac_reg[2.net89 = 3.3000
+ xadc8.xi1.xstartphasesample_reg.ci = 25.3073n
+ xadc8.xi1.xstartphasesample_reg.cn = 3.3000
+ xadc8.xi1.xstartphasesample_reg.net40 = 40.2479n
+ xadc8.xi1.xstartphasesample_reg.net47 = 3.3000
+ xadc8.xi1.xstartphasesample_reg.net48 = 3.3000
+ xadc8.xi1.xstartphasesample_reg.net55 = 29.2595n
+ xadc8.xi1.xstartphasesample_reg.net57 = 3.3000
+ xadc8.xi1.xstartphasesample_reg.net63 = 18.2711n
+ xadc8.xi1.xstartphasesample_reg.net80 = 3.3000
+ xadc8.xi1.xstartphasesample_reg.net89 = 3.3000
+ xadc8.xi1.xdac_reg[3.ci = 25.3073n
+ xadc8.xi1.xdac_reg[3.cn = 3.3000
+ xadc8.xi1.xdac_reg[3.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[3.net47 = 3.3000
+ xadc8.xi1.xdac_reg[3.net48 = 3.3000
+ xadc8.xi1.xdac_reg[3.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[3.net57 = 3.3000
+ xadc8.xi1.xdac_reg[3.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[3.net80 = 3.3000
+ xadc8.xi1.xdac_reg[3.net89 = 3.3000
+ xadc8.xi1.xdac_reg[5.ci = 25.3073n
+ xadc8.xi1.xdac_reg[5.cn = 3.3000
+ xadc8.xi1.xdac_reg[5.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[5.net47 = 3.3000
+ xadc8.xi1.xdac_reg[5.net48 = 3.3000
+ xadc8.xi1.xdac_reg[5.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[5.net57 = 3.3000
+ xadc8.xi1.xdac_reg[5.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[5.net80 = 3.3000
+ xadc8.xi1.xdac_reg[5.net89 = 3.3000
+ xadc8.xi1.xdac_reg[1.ci = 25.3073n
+ xadc8.xi1.xdac_reg[1.cn = 3.3000
+ xadc8.xi1.xdac_reg[1.net40 = 40.2479n
+ xadc8.xi1.xdac_reg[1.net47 = 3.3000
+ xadc8.xi1.xdac_reg[1.net48 = 3.3000
+ xadc8.xi1.xdac_reg[1.net55 = 29.2595n
+ xadc8.xi1.xdac_reg[1.net57 = 3.3000
+ xadc8.xi1.xdac_reg[1.net63 = 18.2711n
+ xadc8.xi1.xdac_reg[1.net80 = 3.3000
+ xadc8.xi1.xdac_reg[1.net89 = 3.3000
+ xadc8.xi1.xu30.net11 = 21.6344n
+ xadc8.xi1.xi_reg[1.ci = 25.3073n
+ xadc8.xi1.xi_reg[1.cn = 3.3000
+ xadc8.xi1.xi_reg[1.net40 = 3.3000
+ xadc8.xi1.xi_reg[1.net47 = 18.2711n
+ xadc8.xi1.xi_reg[1.net48 = 92.6025n
+ xadc8.xi1.xi_reg[1.net55 = 3.3000
+ xadc8.xi1.xi_reg[1.net57 = 49.9426n
+ xadc8.xi1.xi_reg[1.net63 = 3.3000
+ xadc8.xi1.xi_reg[1.net80 = 3.3000
+ xadc8.xi1.xi_reg[1.net89 = 81.6141n
+ xadc8.xi1.xeoc_reg.ci = 25.3073n
+ xadc8.xi1.xeoc_reg.cn = 3.3000
+ xadc8.xi1.xeoc_reg.net40 = 3.3000
+ xadc8.xi1.xeoc_reg.net47 = 18.2711n
+ xadc8.xi1.xeoc_reg.net48 = 102.3736n
+ xadc8.xi1.xeoc_reg.net55 = 3.3000
+ xadc8.xi1.xeoc_reg.net57 = 54.8281n
+ xadc8.xi1.xeoc_reg.net63 = 3.3000
+ xadc8.xi1.xeoc_reg.net80 = 3.3000
+ xadc8.xi1.xeoc_reg.net89 = 91.3851n
+ xadc8.xi1.xstartphaseeoc_reg.ci = 25.3073n
+ xadc8.xi1.xstartphaseeoc_reg.cn = 3.3000
+ xadc8.xi1.xstartphaseeoc_reg.net40 = 3.3000
+ xadc8.xi1.xstartphaseeoc_reg.net47 = 18.2711n
+ xadc8.xi1.xstartphaseeoc_reg.net48 = 102.3736n
+ xadc8.xi1.xstartphaseeoc_reg.net55 = 3.3000
+ xadc8.xi1.xstartphaseeoc_reg.net57 = 54.8281n
+ xadc8.xi1.xstartphaseeoc_reg.net63 = 3.3000
+ xadc8.xi1.xstartphaseeoc_reg.net80 = 3.3000
+ xadc8.xi1.xstartphaseeoc_reg.net89 = 91.3851n
+ xadc8.xi1.xi_reg[0.ci = 25.3073n
+ xadc8.xi1.xi_reg[0.cn = 3.3000
+ xadc8.xi1.xi_reg[0.net40 = 3.3000
+ xadc8.xi1.xi_reg[0.net47 = 18.2711n
+ xadc8.xi1.xi_reg[0.net48 = 92.6025n
+ xadc8.xi1.xi_reg[0.net55 = 3.3000
+ xadc8.xi1.xi_reg[0.net57 = 49.9426n
+ xadc8.xi1.xi_reg[0.net63 = 3.3000
+ xadc8.xi1.xi_reg[0.net80 = 3.3000
+ xadc8.xi1.xi_reg[0.net89 = 81.6141n
+ xadc8.xi1.xdac_reg[0.ci = 25.3073n
+ xadc8.xi1.xdac_reg[0.cn = 3.3000
+ xadc8.xi1.xdac_reg[0.net40 = 3.3000
+ xadc8.xi1.xdac_reg[0.net47 = 18.2711n
+ xadc8.xi1.xdac_reg[0.net48 = 102.3736n
+ xadc8.xi1.xdac_reg[0.net55 = 3.3000
+ xadc8.xi1.xdac_reg[0.net57 = 54.8281n
+ xadc8.xi1.xdac_reg[0.net63 = 3.3000
+ xadc8.xi1.xdac_reg[0.net80 = 3.3000
+ xadc8.xi1.xdac_reg[0.net89 = 91.3851n
+ xadc8.xi1.xi_reg[2.ci = 25.3073n
+ xadc8.xi1.xi_reg[2.cn = 3.3000
+ xadc8.xi1.xi_reg[2.net40 = 3.3000
+ xadc8.xi1.xi_reg[2.net47 = 18.2711n
+ xadc8.xi1.xi_reg[2.net48 = 92.6025n
+ xadc8.xi1.xi_reg[2.net55 = 3.3000
+ xadc8.xi1.xi_reg[2.net57 = 49.9426n
+ xadc8.xi1.xi_reg[2.net63 = 3.3000
+ xadc8.xi1.xi_reg[2.net80 = 3.3000
+ xadc8.xi1.xi_reg[2.net89 = 81.6141n
+ xadc8.xi0.xi9.net18 = 3.3000
+ xadc8.xi0.xi9.net7 = 1.4082
+ xadc8.xi0.xi0.net11 = 1.6455n
+ xadc8.xi0.xi0.net14 = 3.3000
+ xadc8.xi0.xi0.net20 = 4.8753n
+ xadc8.xi0.xi0.net22 = 107.1041n
+ xadc8.xi0.xi0.net26 = 107.1041n
+ xadc8.xi0.xi0.net28 = 3.3000
+ xadc8.xi0.xi0.net30 = 3.3000
+ xadc8.xi0.xi0.net35 = 3.3000
+ xadc8.xi0.xi0.net36 = 3.3000
+ xadc8.xi0.xi0.net52 = 4.8753n
+ xadc8.xi0.xi0.net65 = 4.8753n
+ xadc8.xi1.xu47.xi3.net14 = 804.2795m
+ xadc8.xi1.xu47.xi3.net18 = 3.3000
+ xadc8.xi1.xu10.xi1.net11 = 625.9707m
+ xadc8.xi1.xu10.xi1.net35 = 14.8357n
+ xadc8.xi1.xu10.xi1.net7 = 2.6619
+ xadc8.xi1.xu21.xi1.net11 = 2.5112
+ xadc8.xi1.xu21.xi1.net35 = 10.7793n
+ xadc8.xi1.xu21.xi1.net7 = 3.3000
+ xadc8.xi1.xu17.xi1.net11 = 642.2539m
+ xadc8.xi1.xu17.xi1.net35 = 40.8517n
+ xadc8.xi1.xu17.xi1.net7 = 670.4791m
+ xadc8.xi1.xu19.xi1.net11 = 625.9707m
+ xadc8.xi1.xu19.xi1.net35 = 14.8357n
+ xadc8.xi1.xu19.xi1.net7 = 2.6619
+ xadc8.xi1.xu46.xi2.net23 = 872.0388m
+ xadc8.xi1.xu46.xi2.net27 = 188.2278m
+ xadc8.xi1.xu46.xi2.net7 = 3.3000
+ xadc8.xi1.xu42.xi2.net23 = 784.7360m
+ xadc8.xi1.xu42.xi2.net27 = 1.0660n
+ xadc8.xi1.xu42.xi2.net7 = 3.3000
+ xadc8.xi1.xu44.xi2.net23 = 784.7360m
+ xadc8.xi1.xu44.xi2.net27 = 1.0660n
+ xadc8.xi1.xu44.xi2.net7 = 3.3000
+ xadc8.xi1.xu7.xi2.net23 = 2.6156
+ xadc8.xi1.xu7.xi2.net27 = 2.5965
+ xadc8.xi1.xu7.xi2.net7 = 3.3000
+ xadc8.xi1.xu23.xi1.net10 = 10.7693n
+ xadc8.xi1.xu23.xi1.net26 = 2.4993
+ xadc8.xi1.xu12.xi1.net10 = 10.7693n
+ xadc8.xi1.xu12.xi1.net26 = 2.4993
+ xadc8.xi1.xu22.xi1.net10 = 10.7693n
+ xadc8.xi1.xu22.xi1.net26 = 2.4993
+ xadc8.xi1.xu14.xi1.net10 = 10.7693n
+ xadc8.xi1.xu14.xi1.net26 = 2.4993
+ xadc8.xi1.xu8.xi1.net10 = 24.6602n
+ xadc8.xi1.xu8.xi1.net26 = 3.3000
+ xadc8.xi1.xu20.xi1.net10 = 10.7693n
+ xadc8.xi1.xu20.xi1.net26 = 2.4993
+ xadc8.xi1.xu18.xi1.net10 = 10.7693n
+ xadc8.xi1.xu18.xi1.net26 = 2.4993
+ xadc8.xi1.xu13.xi1.net10 = 10.7693n
+ xadc8.xi1.xu13.xi1.net26 = 2.4993
+ xadc8.xi1.xu24.xi1.net10 = 10.7693n
+ xadc8.xi1.xu24.xi1.net26 = 2.4993
+ xadc8.xi1.xu11.xi1.net10 = 10.7693n
+ xadc8.xi1.xu11.xi1.net26 = 2.4993
+ xadc8.xi1.xu9.xi1.net10 = 10.7693n
+ xadc8.xi1.xu9.xi1.net26 = 2.4993
+ xadc8.xi1.xout_reg[6.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[6.xi58.net18 = 40.4023n
+ xadc8.xi1.xout_reg[5.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[5.xi58.net18 = 311.0360m
+ xadc8.xi1.xout_reg[3.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[3.xi58.net18 = 311.0360m
+ xadc8.xi1.xout_reg[7.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[7.xi58.net18 = 40.4023n
+ xadc8.xi1.xout_reg[0.xi58.net10 = 2.5229
+ xadc8.xi1.xout_reg[0.xi58.net18 = 528.7423a
+ xadc8.xi1.xout_reg[4.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[4.xi58.net18 = 311.0360m
+ xadc8.xi1.xout_reg[2.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[2.xi58.net18 = 311.0360m
+ xadc8.xi1.xout_reg[1.xi58.net10 = 3.3000
+ xadc8.xi1.xout_reg[1.xi58.net18 = 40.4023n
+ xadc8.xi1.xdac_reg[6.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[6.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[6.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[6.xi50.net18 = 763.4872m
+ xadc8.xi1.xdac_reg[4.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[4.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[4.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[4.xi50.net18 = 763.4873m
+ xadc8.xi1.xdac_reg[7.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[7.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[7.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[7.xi50.net18 = 3.2397n
+ xadc8.xi1.xdac_reg[2.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[2.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[2.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[2.xi50.net18 = 763.4873m
+ xadc8.xi1.xstartphasesample_reg.xi59.net13 = 763.4873m
+ xadc8.xi1.xstartphasesample_reg.xi58.net13 = 763.4874m
+ xadc8.xi1.xstartphasesample_reg.xi50.net10 = 3.3000
+ xadc8.xi1.xstartphasesample_reg.xi50.net18 = 3.2397n
+ xadc8.xi1.xdac_reg[3.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[3.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[3.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[3.xi50.net18 = 763.4873m
+ xadc8.xi1.xdac_reg[5.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[5.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[5.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[5.xi50.net18 = 763.4873m
+ xadc8.xi1.xdac_reg[1.xi59.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[1.xi58.net13 = 763.4874m
+ xadc8.xi1.xdac_reg[1.xi50.net10 = 3.3000
+ xadc8.xi1.xdac_reg[1.xi50.net18 = 763.4873m
+ xadc8.xi1.xu30.xi6.net10 = 3.3000
+ xadc8.xi1.xu30.xi6.net18 = 24.8177n
+ xadc8.xi1.xu30.xi5.net10 = 642.9341m
+ xadc8.xi1.xu30.xi5.net18 = 32.5566n
+ xadc8.xi1.xi_reg[1.xi61.net13 = 763.4873m
+ xadc8.xi1.xi_reg[1.xi60.net13 = 763.4873m
+ xadc8.xi1.xi_reg[1.xi52.net10 = 2.5229
+ xadc8.xi1.xi_reg[1.xi52.net18 = 528.7429a
+ xadc8.xi1.xeoc_reg.xi61.net13 = 763.4873m
+ xadc8.xi1.xeoc_reg.xi60.net13 = 763.4872m
+ xadc8.xi1.xeoc_reg.xi52.net10 = 3.3000
+ xadc8.xi1.xeoc_reg.xi52.net18 = 40.4024n
+ xadc8.xi1.xstartphaseeoc_reg.xi61.net13 = 763.4873m
+ xadc8.xi1.xstartphaseeoc_reg.xi60.net13 = 763.4872m
+ xadc8.xi1.xstartphaseeoc_reg.xi52.net10 = 3.3000
+ xadc8.xi1.xstartphaseeoc_reg.xi52.net18 = 40.4024n
+ xadc8.xi1.xi_reg[0.xi61.net13 = 763.4873m
+ xadc8.xi1.xi_reg[0.xi60.net13 = 763.4873m
+ xadc8.xi1.xi_reg[0.xi52.net10 = 2.5229
+ xadc8.xi1.xi_reg[0.xi52.net18 = 528.7429a
+ xadc8.xi1.xdac_reg[0.xi61.net13 = 763.4873m
+ xadc8.xi1.xdac_reg[0.xi60.net13 = 763.4872m
+ xadc8.xi1.xdac_reg[0.xi52.net10 = 3.3000
+ xadc8.xi1.xdac_reg[0.xi52.net18 = 40.4023n
+ xadc8.xi1.xi_reg[2.xi61.net13 = 763.4873m
+ xadc8.xi1.xi_reg[2.xi60.net13 = 763.4873m
+ xadc8.xi1.xi_reg[2.xi52.net10 = 2.5229
+ xadc8.xi1.xi_reg[2.xi52.net18 = 528.7429a
+ xadc8.xi1.xu3.xi1.net17 = 2.5668
+ xadc8.xi1.xu41.xi1.net18 = 3.0989
+ xadc8.xi1.xu41.xi1.net22 = 2.4248
+ xadc8.xi1.xu28.xi1.net17 = 3.3000
+ xadc8.xi1.xu6.xi1.net17 = 3.3000
+ xadc8.xi1.xu34.xi1.net17 = 3.3000
+ xadc8.xi1.xu33.xi1.net17 = 642.9340m
+ xadc8.xi1.xu51.xi1.net13 = 804.2796m
+ xadc8.xi1.xu16.xi1.net13 = 2.6103
+ xadc8.xi1.xu37.xi1.net13 = 5.7819n
+ xadc8.xi1.xu43.xi1.net13 = 5.7819n
+ xadc8.xi1.xu45.xi1.net13 = 23.7668n
+ xadc8.xi1.xu32.xi1.net13 = 804.2796m
+ xadc8.xi1.xu38.xi1.net13 = 2.6103
+ xadc8.xi1.xu31.xi1.net13 = 5.7819n
+ xadc8.xi1.xu25.xi1.net13 = 804.2796m
+ xadc8.xi1.xu35.xi1.net13 = 5.7819n
+ xadc8.xi1.xu50.xi1.net13 = 2.6103
+ xadc8.xi1.xu27.xi1.net13 = 2.6103
+ xadc8.xi1.xu15.xi1.net13 = 23.7668n
+ xadc8.xi1.xu26.xi1.net13 = 804.2796m
+ xadc8.xi1.xu36.xi1.net13 = 2.6103
+ xadc8.xi1.xu39.xi1.net10 = 188.2278m
+ xadc8.xi1.xu39.xi1.net6 = 872.0388m
+ xadc8.xi1.xu40.xi1.net10 = 620.2368m
+ xadc8.xi1.xu40.xi1.net6 = 2.6312
+ xadc8.xi1.xu29.xi2.net15 = 2.6103
+ xadc8.xi1.xu29.xi2.net23 = 3.3000
+ xadc8.xi1.xu29.xi2.net7 = 5.7819n
+ xadc8.xi0.xi0.xi119.net17 = 2.5200
+ xadc8.xi0.xi0.xi118.net17 = 3.3000
*** END: Saved Operating Point ***
two ways. one, add uic behind .tran .. statament.
The other, change .nodeset to .ic in .ic0 file, and add .include xx.ic0 to your netlist.
Also some times help to make power up save initial conditions after power-up and use them for any other transient simulation.
I would recommend you to reduce the step size first.
.tran 0.2us 20us is very ridiculous in transient simulation with only 100 points for the ADC.
Try
.tran 1ns 20us and I don't think you should take long time to simulate.
