Wide input Switching mode power supply ?
msmax
Full Member level 1
Pays Bas
I need to design a 230-480VAC input/ 17VDC-1A power supply in very compact size.
Any idea's where to start?
You could start here:
You can modify the following schematic to obtain 17V / 1A. I sugest you to use a bipolar - vmos cascode structure for the power switch because a high voltage vmos is expensive.
If you are interested I can upload my modified (and tested) version.
Thanks for the links! THIS is information!
Maduran: Please send me/upload your tested version.
I will built this one for my first tests.
Looks quite forward with good test results.
Here is my project. The archive contains the project Prot.ddb. I am sure that you know with what kind of program can you open it! If you do not have that program you can use the other files from the archive.
If you will need more informations contact me at: hrim@softronic.ro
check topswitch designs: w0w.powerint.com You will find some programs for trafo calculation,
best,
//a
