serial connection b/w micro and PC
markids
Newbie level 3
hey
i want to interface my microcontroller 89C52 with PC hyperterminal
how shoul i connect the serial connectors at both ends??????
tx-tx
rx-rx
gnd-gnd
TX(PC)-to-RX(micro) ..
RX(PC)-to-TX(micro) ..
GND-to-GND ..
Use MAX232 (or similar) as level converter ..
(1mF ==> 1µF)
Regards,
IanP
hi,
u have to make the Null modem configration b/w the PC and controller card
AT PC End
pin 4 and pin 6 (Short)
pin 8 and pin 7 (short)
and for TX and RX use cross cable configration
if any qurey then feel free to ask (about programming)
Hi
I think we may not need the following - it is already shorted at PC END
AT PC End
other references:
thanks
ashad wrote :
AT PC End
Ignore above connection if you set HyperTerminal's Com Property - Port Setting - Flow Control = NONE
this link tells about hyperterminal and AVR uC interfacing
bibin john
www.bibinjohn.tk
